Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Where there are crystals to buy <10ppm
Old 30th September 2005, 06:19 PM   #1
Sabas is offline Sabas  Spain
Question Where there are crystals to buy <10ppm
I live in Spain/Europe and have found this Web that I suppose that she will be of his interest.
https://www.icmfg.com/order_precisioncrystals.html
For frequencies 11.2896 and 16.9344 MHz
Also I am interested in: VCXO, TCXO or OCXO
Old 30th September 2005, 08:19 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Where there are crystals to buy &lt;10ppm
I'll guess you shall use the oscillator for digital audio, then the ppm is rather unimportant. You should concentrate your search for low jitter instead.
How much ppm do you actually hear and much jitter do you hear? You can't hear 1000 ppm so paying extra for 10 ppm is a wate of money.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 1st October 2005, 03:12 AM   #3
Extreme_Boky is offline Extreme_Boky  Australia
Try Crystek crystal oscillators.
<1ps jitter max. over specified!!! range... 5V supply! US$3!
Extreme_Boky
Old 1st October 2005, 02:00 PM   #4
tommak is offline tommak  United States
Default Crystek crystal oscillators
Any idea where the best place to purchase the Crystek crystal oscillators is, in the required frequencies? Mouser didn't appear to have them in 11.2896 or 16.9344 MHz.
Tom
Old 1st October 2005, 04:06 PM   #5
peranders. Thanks to respond
The crystal is for a clock of cdplayer to synchronize with dac external. The exactitude of the clock derives in a smaller variation of the frequency of the clock and therefore in a smaller error of the data.
Old 1st October 2005, 04:24 PM   #6
peranders's Avatar
If you have only one clock source the absolute frequency isn't very important.
Old 1st October 2005, 11:40 PM   #7
Jocko Homo is offline Jocko Homo  United States
Banned
Default No, no, no, no, no.......
The exactitude has nothing to do with it. You are not going to hear the difference if it is 10 ppm or 1000 ppm.
Only time it will be a problem is when you have a PLL on the RX end, like on SPDIF, and you have a VCXO with a very limited pull range. (As most do.) Then you have to worry. I think the Redbook standard is either 100 or 200 ppm. I could be wrong about the standard, but most VCXOs can handle that amount.
Forget about the damn ppm and concentrate on jitter. How many times do we have to say this?
Jocko
Old 2nd October 2005, 04:58 AM   #8
hagtech is offline hagtech
hagtech's Avatar
Even if your crystal is specified to +/-1ppm tolerance, it don't mean much once you put in into an oscillator circuit. There, the loading capacitance can push or pull the resultant frequency well off center.
Note, the xtal tolerance is only good at exact loading value. And like Jocko says, Redbook is +/-100ppm, so it's not a big deal. Certainly not a noticeable pitch change.
Manufacturers (hey, I'm one of them) often brag about useless specs. Customers can easily get caught up in a numbers game. It's not always easy to know what counts. For example, the orthognal reflection coefficient of the front panel of my linestage is 0.12 (12% +/-1%, depending on time of day). That's an extremely tight 1%.
jh
Old 2nd October 2005, 08:37 AM   #9
Ok. I will load the crystal with the condenser that specifies the manufacturer and I will be centered in a good power supply and the own circuit of the clock and in the buffer.
Now I have a crystal of 30ppm. I will be based on him to make the clock.
Old 2nd October 2005, 02:15 PM   #10
Guido Tent is offline Guido Tent  Netherlands
Extreme_Boky
Hi
What frequency components are included in that range ?
best
Guido Tent
www.Tentlabs.com
Where there are crystals to buy &lt;10ppmHide this!Advertise here!
Accurate 50ppm Crystals fmak Digital Source 6 5th June 2008 03:24 PM
Who makes the best crystals ? percy Digital Source 18 5th April 2006 02:18 PM
22.5792 MHz crystals (also 26.2144) danville Swap Meet 0 15th June 2004 11:46 PM
where can I buy CD player crystals? jarthel Digital Source 0 3rd May 2002 01:09 PM
Copyright ©1999-2017 diyAudio
