| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi Guys,
Working on my CD-63 SE. Has clock and digital power supply mods, mains filter, plus damping etc. and I am now starting to look at what I will do to the analogue stage. Options seem to be either 1) do caps, op-amps, remove mute transistors and caos, power supply etc. 2) simply replace the analogue stage with a discrete one such as the ZAPfilter (or maybe others - that is the one I know). Before I start putting $ into the component by component approach, I would appreciate hearing people's thoughts on which one is likely to result in better sound quality for the sort of $ involved to buy a ZAPfilter - about US$200. My electronics expertise is limited, and so the concept of replacing the entire output has some appeal since I could do that. Doing the mods required to the existing analogue stage is where I would have difficulty. I could do it from the mechanical perspective, but where I would have trouble is really working out exactly where to start, what was the best order to replace components, best 'bang for my buck' etc. Thanks in advance, Dave |
#2 |
Hi Dave
I have modded a CD 63SE by doing the following: Replaced all diodes with BYV26C Bypass power supply caps with MKP/MKP types Clock hack as described at: http://www.acoustica.org.uk/t/63/63hacks.html All this yielded a vast improvement, particularly extension at the frequency extremes. A shielded power cord also worked wonders. I have also had good success with opamp replacement AD826, OPA2604 in older philips based players. However there are recommendations for the LM6172/82 type opamps for players with a bistream dac. This would be an easy and cheap upgrade before you try an output stage. A search of the forum will produce some DIY ideas for "transistor output stages", perhaps their creators would like to comment. Hope this helps Cheers Richard |
| Analogue output stage | maxpou | Digital Line Level | 0 | 18th April 2009 02:48 PM |
| Help on improved analogue stage | p.heimpold | Digital Source | 1 | 17th March 2007 09:16 AM |
| TDA1540 analogue stage | dariusku | Digital Source | 2 | 9th September 2005 07:01 AM |
| cdp analogue stage tweak | ohynot | Digital Source | 2 | 11th July 2004 08:36 AM |
| Page generated in 0.07157 seconds (68.07% PHP - 31.93% MySQL) with 10 queries |
