Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th September 2005, 06:07 AM   #1
ruting is offline ruting  Netherlands
Default CD960 belts specs & service manual
Hello friends of DuyAudio,
1. I own a CD960 with it's rewarded transport. The belts are worn/stretched and I try to get replacements. Does anyone have formal specs of the diameters and thickness of the square belts (4 in total) and recoomendations where to buy them in the Netherlands?
2. If anyone has a technical service manual on this machine I would be delighted to get a copy.
3. Last but not least, what's your experience with hooking up a separate DA convertor. Should I use optical of coax digital out? What is a fair priced DA convertor which realy sounds nice, you reccomend to me to look for?
I have a power amp with Balanced inputs so perhaps there is also a DA convertor (with attanuator) which I feed directly into the power amp.
Old 29th October 2005, 12:46 AM   #2
IanAS is offline IanAS  England
You can get original replacement belts from SEME in the UK and Charles Hyde in the UK. Say you have a Marantz CD94, it's the same mechanism.
About £30 for the 4 belts. Tray belt, Cam belt, and two Motor belts (the small thin ones).
OR...
CPC do a range of near enough size belts, cost about £2 for all four.
http://cpc.farnell.com/jsp/endecaSea...&No=75#results
AVBELT77 £0.26 37 x 1.9mm ( original=36.2x1.6) it will do for both Cam drive (the tray lifter) and Motor and belts.
AVBELT91 £0.55 51.5 x 2mm Tray drive belt (the very long one)
Old 30th May 2008, 03:45 PM   #3
Rob_N is offline Rob_N  United Kingdom
Are the belts the same for the CD12?
Old 30th May 2008, 09:33 PM   #4
I think so.
We've recently found that the supposedly OEM belts supplied by SEME and Charles Hyde vary in length.
Comparing the original and new belts we had 3 different lengths for each belt size. The CPC belts are different again.
None of the new belts were good enough on the last 960 repair. The new ones were too stretchy or seemed to have lost their grip. We reused some old original belts from various donor CDM1 Philips players and moved the motors so they were further from the pulleys. That tightened the belts a bit.
Old 7th July 2008, 01:26 PM   #5
Just a bit more info in case it helps anyone:
Philips part numbers for the belts:
Tray 482235830903
Cam 482235830763
Motor 482235830762
Tray is the long one.
Cam is the short thick one.
Motor are the two short thin ones that go on the motor pulleys.
Same numbers for the Marantz CD94.
I think the OE tray belt might be 2.2mm diameter, so 10% thicker than the CPC AVBELT91. That might mean it stretches less and maybe works better.
Old 7th July 2008, 01:37 PM   #6
oshifis is offline oshifis  Hungary
This thread is about the Marantz CD94 which has the same belts, I suppose:
Marantz cd94: belts for loading tray
Old 7th July 2008, 02:28 PM   #7
Thanks for linking the threads.
Yes, they are the same belts in the CD94 and are interchangeable with the CD960 belts.
I just phoned Charles Hyde and bought their last two tray belts.
The motor and cam belts from them are discontinued.
From SEME the tray drive belt is discontinued.
Old 25th June 2010, 09:48 AM   #8
tiefbassuebertr's Avatar
Tray 482235830903
Cam 482235830763
Motor 482235830762
Belt for the tray, part No from Philips 4822 358 30903 (482235830903) for me unknown.
Therefore I have study some service manuals for the Marantz CD-7 and CD-94
(Philips CD-304 MK-II and CD-960 uses the same Loader A'ssy)
Here a more exactly describtion of all needed belts for Philips CD-960,
Marantz CD-94, Philips CD-304 MK-II and partly Marantz CD-7
so as some Philips compact disc player from LHH series.
Follow belts are necessary for loader A'ssy A001, used both for old CDM-2/CDM-4
and new VAM12xx mechanism units,
Philips/Marantz loader part No 482269110787/355K304520+355K304510:
1) Belt 051M part No 4822 358 30762 (482235830762) / 167K264010 Motor M003
Belt from pulley 049M on motor M003 to pulley 047M (= pulley, clamperdrive 167K262020)
Belt with the shortest life time
2) Belt 052M part No 4822 358 30763 (482235830763) / 167K264020 CAM DRIVE
Belt from 047M (= pulley, clamperdrive 167K262020) to 045M (CAM, clamperdrive 167K054010)
3) Belt 025M part No 4822 358 30762 (482235830762) / 167K264010 (same Part No than 051M)
Belt from Pulley 021M on Motor M002 to Tray Drive Pulley
4) Belt 026M part No I find only from Marantz, No 167K264030
Belt from Tray Drive Pulley to Wire Wheel Pulley
Philips part No unknown, maybe identical with 026M from Marantz CD7 exploded view
part No 4822 358 31065/ 221K264010 go to
http://www.bgaudioclub.org/uploads/d...tz_CD-7_SM.pdf
Old 25th June 2010, 11:31 AM   #9
PetrL is offline PetrL  Czech Republic
You can repair sliping belts by shortening them. Cut-out 2-3 mm and glue together by cyanoacrylat glue. Route the cuts in skew direction, not perpendicular.
Repaired the 051M belt and it works again.
Old 25th June 2010, 06:04 PM   #10
This is a good solution, if new devices are no longer available and if the rubber material isn't brittle (cracking through fissures). If I want to get special diameter sizes (individual belts), current meter of belt materials with certainly thickness is necessary. If I have this I can carried out the same methody. I have heard about such suppliers but I have forget the exactly delivery sources; perhaps you know this.
For additional informations about the exct belt sizes for the loader of this model go to
Help with Philips CD960
Alpine 3539 2 Ch Amp (looking for specs and or service manual) turbo_slug Car Audio 4 16th September 2008 12:06 AM
Seek help: Leader LDM-171 user manual (Service Manual) 0451ym Parts 0 28th June 2008 04:18 PM
Schematics or service manual for philips cd960 kipperville Digital Source 0 13th September 2007 04:12 AM
skytec 6950 amp wrong specs on manual joka22 Solid State 0 15th July 2007 08:51 PM
F1 Service Manual Nelson Pass Pass Labs 59 18th August 2005 11:00 PM
Page generated in 0.11101 seconds (81.05% PHP - 18.95% MySQL) with 10 queries
