| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1 | |
I was very impressed and inspired by hifiZen's NS500V mods in this thread. So I decided to do these on my player--however, I'm using DVP-NC650V, the 5-disc carousel version of the NS500V. Its design is similar but not identical.
For your reference, here are two pictures of the audio PCB: Labeled photo Sharper unlabeled photo So far, I have successfully removed/bypassed C247 and C248 (hifiZen bypassed the same-numbered capacitors). However, I still wonder if I should instead have removed C253 or C254 instead (basically, which caps belong to which Output, #1 or #2)... maybe I should desolder my cap bypasses and see which output gets muted? My other questions: 1) Where to get the parts (preferably cheaply)? hifiZen mentioned using: * Analog Devices AD8620 opamp * two 1uF Panasonic HF decoupling caps (he implied HFQs would be even better) * see below, a Holco resistor is used--basically, I need a good 30-ohm resistor for my purposes here 2) Any advice on finding the equivalents of hifiZen's other mods? It's pretty obvious how to change the opamp and to kill neighboring muting transistors. However, what about bypassing the output resistors, like so (post by dorkus): Quote:
Any help or suggestions welcome! --Leo |
#2 |
For reference, here is hifiZen's main list of mods:
A couple more questions: 3) In HifiZen's first pic, are the black opamp decoupler capacitors soldered in place of removed mute transistors? It's hard to tell from the picture where the mute transistors were removed. 4) What does "remove C280 and C281 (220pF) caps to ground" mean? Thanks, --Leo |
#3 |
Leo,
Thanks for the compliments! So let's see here... Boy, that analog board looks a lot like the NS500 one! I got the schematics by ordering the service manual straight from Sony... you may be able to do the same, but I don't have a part number for the 650V. The service manual was quite affordable - maybe $30 or so. AD8620 should be available from Newark and Allied Electronics (both carry Analog Devices, AFAIK), but don't seem to show up on their web sites. You may also be able to get them as samples(?). Actually, if anyone else knows of a good supplier for Analog Devices parts, I'd like to know! You could also use the OPA2134, which should sound excellent here as well, and seem to be easier to obtain. The mute transistors were removed from the two larger circles shown at the upper right side of the image, near the chassis metal. There was nothing put in their place. The big decoupling caps were actually soldered right in place over the existing ceramic chip decoupling caps... if you look closely you'll see them still there at the ends of the cap leads. C280 and C281 were located in the circles next to the silkscreen labels C277 and C278. Confused? Me too. I hope I didn't get those part numbers wrong. Anyway, they were a shunt to ground after the series output resistor. From the pics of your board, you don't seem to have these caps, so I wouldn't worry about them. If I were smart, I would have colour coded the pictures like yours... oh well. Next time.
- Chad. |
#4 | |
Chad,
Great to hear from you in person! I called up both AD suppliers, but neither had the parts. I also found this surprising itty-bitty over at SACDmods (the people who charge over $300 for ns500v mods: ) Quote:
Also wondering, what NS500 settings do you use? I heard some people enable the "CD Direct" option to bypass unnecessary circuitry during playback. I'm wondering if that would also bypass any upsampling circuitry, which could be a bad thing. I just want to make sure all the "easy tweaks" are done right first Anyway thanks for all the feedback! Leo |
#6 |
I just removed what I believed were the mute transistors: Q214 and Q215 as seen in the picture. However, to my surprise I didn't hear any power on/off transients! Just same normal operation. Any way to explain this?
Thanks, Leo PS: Any other parts to get at Newark besides the OP2134? (Still looking for those 2 capacitors and resistor..) |
#7 |
diyAudio Moderator Emeritus
Leo,
That is the part that you are looking for. You can get 3 free samples of the opa2134 at ti.com and you can get 2 free samples of the ad opamps at analog.com That way, you can try the devices and see what ones you like before going and buying from newark.com That is what I have done. -- Brian |
#8 |
Neat, I just ordered 2 samples of each. Thanks a lot Brian! The samples are identical to the real thing, right?
Which do you think is "better" for the NS500V/NC650V, the OPA2134 or AD8620? It would be very painful to solder/desolder both... Thanks, Leo |
#10 |
***UPDATE*** I just downloaded NC650V's schematics, and posted them here:
block diagram (71KB) detailed diagram (288KB) full schematic (419KB) As you can see, there are a couple differences from NS500V! Any observations? I removed the correct muting transistors (Q214 and Q215), but I hear no power on/off transient sound. Is that good luck? --Leo |
| Sony DVP NS500V SACD player | jag | Swap Meet | 0 | 4th October 2008 10:22 PM |
| mods on the cheap (sony ns500v) | Pangloss | Digital Source | 3 | 14th May 2005 12:35 AM |
| Sony NS500V SACD mods | Davet | Digital Source | 0 | 28th April 2004 06:58 PM |
| Looking for sony schematics (ce775 and ns500v) | BrianGT | Digital Source | 8 | 13th August 2002 01:35 AM |
| Page generated in 0.12166 seconds (82.81% PHP - 17.19% MySQL) with 10 queries |
