| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a USB kit with PCM2706/TDA1543 dac on hand. The schematics is as follows: http://www.audioworkshop.com.hk/download/AW_D3.pdf I have already replace the usb power for the pcm2706 and pull the power from the lt317 using a tl431 for 5v. There is some improvement after this mod but I can improve this further by using the self-power mode. I tried to convert the circuit for pcm2706 for self-power mode but failed, got a "malfunction usb device error". Here is what I did: 1. cut the trace and put the P-sel pin to ground 2. connect the Host pin to USB power with 1M resistor to ground 3. connect all voltage pins to a 3.3V power. Is there anything else I missed? Thanks in advance. BTW, this dac sound very good, (direct out to a NI gainclone without buffer) I will stack another 1543 on top for my next tweak. |
#2 |
Do you feed in 3.3V in VCCP/Pin 2 ?
Franz |
#3 |
Pin 2? yes, 3.3v to all V pins. Vdd, Vbus, Vccl, Vccr, Vcom, Vccp.
Host pin 5V from usb. Psel to ground. |
#4 |
This is one of the implementations I've come across which might be helpful with regard to which pins require 3.3v for self power.
#5 |
This is the other one:
#6 |
I finished my first PCM2706 DAC some days ago, to play with different modes.
But, I did not realize, that FSEL must set high to use the internal DAC, same setting as for SPDIF-out. In the link from audioworkshop you pointed to, Chuck, I found the little comment about FSEL (J2 in this circuit) and got my DAC playing now. BTW: I found, the chip is sounding better with 4V (actually trying 4.3V Franz |
#7 |
Thanks for the circuit, Cyteen.
It seems the Vcom, Vccl, Vccr do not need to be connected to 3.3v, that strange. I recheck the datasheet, Vcom don't need to be connected but Vccl, Vccr should be connect, this pin is for the dac/analog output. Hi Franz, good work, yeah the Fsel needs to be selected between SPIF out or internal dac. Are u using the self-power mode? |
#8 |
I could drastically improve the sound of the first version, by
- decoupling the Vccl/Vccr from the digital voltages by CLC-filter 1000uF/330uH/1000uF - replacing the 0.022uF MKT caps in the I/V conversion by sowjet MKP's. This caps are a key part, when using internal DAC. - adjusting the voltage to 3.99VDC (by listening, with regulated supply). It's sounding definitively better than anything else I heard out of a PC! Franz |
#9 |
Franz, did you set the Psel pin high or low (to ground).
Yes, they very good by itself. I also add your decoupling, but just couldn't bypass the internal regulator.... hey, what am I saying, you are using it in self-power mode, otherwise, you couldn't set it to 3.99v! Could you tell me which of the V pins are connected to your 3.99v (that is a pretty precise voltage) |
#10 |
That makes sense now I think about it, the above were for i2s only operation. I was forgetting the D3 has the option of either i2s to the tda1543 or the internal DAC.
I have one of these kits on its way, should be with me in a week or so. One of the other suggested tweaks is to replace the 12Mhz crystal with a Crystek C3390 XO clock. Any other comments you have about the build would be appreciated. |
| Pcm2706-tda1543 Usb Nos Dac - Aw-d3 | pftrvlr | Swap Meet | 0 | 10th November 2008 02:35 AM |
| PCM2706 not working | Eddy Dean | Digital Source | 13 | 23rd August 2008 09:55 PM |
| Pcm2706 -> I2s -> Tda1541a ? | pftrvlr | Digital Source | 3 | 3rd August 2008 04:39 PM |
| Possible PCM2706 implementation | jaycee | Digital Source | 9 | 5th November 2006 11:14 PM |
| 3.3V PSU to drive PCM2706 USB DAC | Nordic | Digital Source | 21 | 11th February 2006 03:09 PM |
| Page generated in 0.09380 seconds (86.39% PHP - 13.61% MySQL) with 11 queries |
