| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I modified my old Magnavox CDB600 (really a Philips machine) CD player. It uses a TDA1543 "twin DAC" DAC chip, and it used to feed op-amp I/V converter circuits. But I found that this DAC chip seems quite happy to feed a resistive load for the I/V circuit. This DAC chip has, for each channel, a constant source current generator, and a varying (to the music) a sink current generator. The difference current between these two goes into/from the resistor load. It wants a bias of about 2.2V for this resistor load (going directly to ground with the resistor doesn't work, sounds awful like severe clipping). This 2.2V bias needs to source or sink current. A conventional voltage regulator chip would only source current but not sink current, so that won't work. But an easy way to create this is to use a voltage divider network, 3k resistor from +5V, 2.4K to ground, to create a thevanin equivalent of a 1.3k resistor going to 2.2V. The DAC develops something like 1Vp-p of audio, which feeds a cathode follower triode grid. I used existing power supply voltages inside this machine to get about 40V for this tube (not a lot, but it seems happy).
I used the light bulb symbol to indicate vacuum tube usage... |
#2 | |
#3 |
"Probably something wrong with Vref." It's working well now, the chip wasn't designed to drive a resistor going to ground.
"purpose of the valve? Just to add lots of ugly distortion and capacitor colourations?" |
#4 |
Just a few comments:
1. The tda1543 is so popular, because it works fine at a supply voltage 8-9 Volts, allowing an almost 2 Volt RMS output. Therefore no need for an extra TUBE stage ..... 2. From your design jpg it is unclear what supply voltage you use for the tda1543. If this is also 5 volt, this will most likely explain the distortion, as you clip the music signal..... 3. An extra tube stage "amplifying" the signal to 0.7 Volt seems useless in regard to point 1. 4. If you want to know about biasing properly a tda1543 and loading it with a resistor correctly you can do a few things: a) search the DIY as suggested before b) read my detailed articles on this subject on my website best regards doede
www.dddac.de Happy listening and building |
#5 |
Originally posted by dddac
Just a few comments: 2. From your design jpg it is unclear what supply voltage you use for the tda1543. If this is also 5 volt, this will most likely explain the distortion, as you clip the music signal..... Okay, should have mentioned it 5V. 3. An extra tube stage "amplifying" the signal to 0.7 Volt seems useless in regard to point 1. Well, I'm a tube head.... 4. If you want to know about biasing properly a tda1543 and loading it with a resistor correctly you can do a few things: Well now I got it to work well, it must not be incorrect b) read my detailed articles on this subject on my website Been there. Unless I missed it, there's no mention what Ibias does or what happens if it's misadjusted. Using several DAC chips in parallel is interesting though. But I'm not convinced that oversampling is bad. There's more than one right answer to many questions... best regards doede |
| 12x TDA1543 at 6V, output and Vref Resistor values | mudihan | Digital Line Level | 9 | 23rd March 2011 09:33 PM |
| Upgrade TDA1543 tube output | ccschua | Digital Line Level | 15 | 24th July 2009 05:18 AM |
| TDA1543 resistor i/v | till | Digital Source | 16 | 5th June 2004 12:19 AM |
| tube buffer for TDA1543 based dac | sparkle | Tubes / Valves | 11 | 25th February 2004 08:24 PM |
| Tube buffer on TDA1543? | sparkle | Digital Source | 0 | 23rd February 2004 07:22 AM |
| Page generated in 0.08849 seconds (79.21% PHP - 20.79% MySQL) with 11 queries |
