| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Since that other thread disintegrated, I'll post my stuff here. Here is a schematic and layout for a 24-bit, 96kHz, stereo DAC. You should be able to build this for less than $300. The board is run from a +/-10V supply fed in through the molex connector at the top. The 16-gauge output pads are, from top to bottom, R-, R+, L+, L-. Coupling capacitors and output resistors are needed, but I left them off so you can make them to your taste. Note also that I have neglected all inputs. Hook them up to pins 4 and 5 on the CS8420 as you wish, and place them in the vast empty space on the board's periphery.
Many features are left as an exercise for the reader. You could make this DAC better, and you could make it cheaper. Please post any modifications you make here! NB: this design is untested, as I have not built it and in fact have no plans to build it. I drew it only because I was intrigued by peranders' idea of a DAC costing less than $300. schematic Gerber files
#2 |
I could not open the gerber files...=/
#3 | |
Electrons are yellow and more is better!
Looks nice, your pcb, but what about analog and digital groundplanes? Crystal claims that this is really important in order to get high S/N. The thing that worries me the most is in fact EMI. These nasty waves seems to wander through my LF-section despite the fact of having separate groundplanes and separate power supplies.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Your "minimalistic" solution can be a good start of a decent DAC.
What is a bad DAC? What is a fair DAC and what is an excellent DAC? Some thinks that only Burr-Brown fits but I have noticed that Crystal and AKM are very common in professional gear, so they can't be that bad. After all, many CD's are created with Crystal and AKM in the signal chain. Just a thought. 300 USD is very realistic if you are lucky, home made pcb's, cheap case, free samples, junkbox full of junk etc.
#5 |
The outputstege is it tested in some other dac design or is it just conceptual?
/micke |
#6 |
Banned
I couldn't open the Gerbers either. Is there an aperature file that we are missing?
I've seen similar I/V schematics up here before. I suggest that you might want to test it first, as some have distortion numbers higher than you might want to accept. Jocko |
#7 |
Well there is no need for I/V conversion with the Cs43122 since it outputs voltage. a buffer should suffice? maybe even transformer coupling?
The LT1962 seems quite hard to find what about somthing simpler like a TL431 ? In my opinion the PCB should be made to be easily made at home that means no traces thinner than 1mm not to many vias. and only 2sides. separate groundplanes should not be so hard to make. Is the AKM dac voltage out? than maybe some form of adaptercard can be used for the dac to make it mor universal? just my 2c /micke btw...is this still peranders show or is it a diyaudio.com project now? |
#8 | ||
#9 | ||
The solution is probably to bring in +10/GND/-10 on the top connector, and add a connector on the bottom for +10/GND. Cut the power traces that cross the slot. Quote:
As I said, this is a simple DAC with embellishments left to the reader. A split ground plane and independent supplies with separate transformers would be one of those embellishments. |
#10 | ||
As for vias, they are critical to performance. Every IC ground pin must have a low impedance path to the ground plane. Every decoupling capacitor, or group of capacitors, should have a via to ground as well. I think I kept vias to a minimum here. There are no vias on signal or power traces, only vias to ground, and I have used only .050", .040", and .020" drills. Quote:
| wich op-amp for cs43122 output? | Ychnaval | Digital Source | 4 | 10th December 2009 02:42 PM |
| Cs43122,ad1955,dir9001 | uhcmos | Swap Meet | 2 | 2nd September 2008 11:22 AM |
| need help, about CS43122 | cubezone | Digital Source | 0 | 7th May 2007 01:41 PM |
| CS43122 output | Prune | Digital Source | 7 | 10th February 2004 06:50 PM |
| Crystal CS43122 DAC | Thomas Giz | Digital Source | 8 | 18th March 2003 03:56 AM |
| Page generated in 0.12274 seconds (83.55% PHP - 16.45% MySQL) with 11 queries |
