| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a short question: I found this schematic on the web. This is a very simple i/v converter for the TDA1545. Can I use this schematic with AD1865? If yes, how? drobert |
#2 |
Magneto the Gravity Man
The answer is yes. DAC in goes to the AOL / AOR ( pins 6 /8 ) on the TDA1543. R8 is used as the I/V converter. On the AD1865, it would go to the equivalent output - pins 4 / 21. Andy |
#3 |
It is sure? I don't understand something. If I connect the AD1865 output to R8. The output of the AD will be about 3,3V. Robert |
#4 | |
The I/U resistor in this shematic is the 22 kohms ad1865 1 ma full scale will give 22 Volts at the output of this circuit (called common grid). There is a problem with this common grid : the dac input is not 0V : then the ad1865 can blow. You have to reference the 375 ohms resistor to a negative supply, to have 0V on the dac input. Go to this post and the rest of this thread : http://www.diyaudio.com/forums/showt...684#post696684 Philippe |
#5 |
OK, I understand it.
But can I use this schematic with TDA1543? What will be a correct value of the Vref? drobert |
#6 | |||
Previously: Kuei Yang Wang
Konnichiwa,
All in all the circuit used with the DAC it is designed for gives a bit above 2V for full scale. Quote:
Sayonara |
#7 | |
Konnichiwa,
The key attraction of the 1543 is that it actually works very well with just a resistor as I/V and an output coupling capacitor to give nearly 2V RMS @ 0dbfs, in other words, no active output stage. Adding an analogue stage only detracts from that. Sayonara |
#8 | |
I agree with you because this 250 R is in fact the input impedance. Then the dac current will flow in this impedance and will give this voltage (2vpp) on it. But replace the 375 R with a constant current source, and then, the I/U resistor will be the plate resistor. Feed 1 ma on the cathode, you will find 1 ma in the plate Resistance, then U = 1ma x plate resistance. http://www.tubecad.com/april_may2001/page24.html http://www.diyaudio.com/forums/showt...684#post696684 Au revoir Philippe |
#9 | |
Bonjour,
It is a poor idea to just copy something without understanding it (and it is not nice to publish others IP without consent or at least attribution), yet it seems a number of Website owners seem happy and even keen to do exactly that. As for the theory of such circuits, I am reasonably well versed in it, thank you very much. At any extent, as is the Circuit is designed for the TDA1545 and ONLY for the 1545 and non else and it works as intended in that application and rather well if I may say so myself. See Ya.... |
#10 |
I ask you then designer of this schematic.
Is it possible to use this (or other very simple common grid) schematic with TDA1543 or not? drobert Sorry, but my English is not to good. |
| My AD1865 nos dac | purer | Digital Source | 10 | 6th July 2008 03:45 PM |
| DC/DC converter to power tube amp? | needtubes | Tubes / Valves | 2 | 24th June 2005 02:35 AM |
| tube i/u converter tda1545 | alchemy | Digital Line Level | 0 | 5th June 2005 07:13 PM |
| Tube as i/v converter | ingram | Digital Source | 10 | 23rd June 2004 01:02 AM |
| Page generated in 0.11544 seconds (80.75% PHP - 19.25% MySQL) with 11 queries |
