Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th February 2006, 06:19 PM   #101
hifimaker's Avatar
Has anyone tried using a single 1794 with it's balanced outputs connected to a Pass I/V stage?
-David
Old 16th March 2006, 08:21 PM   #102
hifimaker's Avatar
Has anyone made any progress on designing a balanced output DAC?
Just curious where the project stands.
-David
Old 17th March 2006, 12:04 AM   #103
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Might take a look at:
http://www.diyaudio.com/forums/show...8700#post868700
Russ and Twisted Pear have already done some great designs and this is looking good.
Old 17th March 2006, 12:05 AM   #104
hayenc's Avatar
http://www.diyaudio.com/forums/showt...700#post868700
Cut and paste never seems to work right.
Old 19th March 2006, 12:37 AM   #105
Banned
Instead of waiting for someone else to design a differential 1704 DAC for you, why don’t you do it yourself? Isn’t that what diyAudio is all about?
Here is a layout idea for four 1704 DACs arranged as differential pairs using through-hole components. It is compact and symmetrical. I did it in about an hour using the free software from ExpressPCB. Four boards with silkscreen and solder mask would cost $179. Three boards without the frills would be $51. Because ExpressPCB doesn’t do bottom side silkscreen, the component outlines are all on the top surface and overlap each other. It’s a bit of a puzzle to figure out which parts go on the top, which go on the bottom, and in what assembly order to make everything go together.
Old 4th January 2010, 03:51 PM   #106
Ava12 is offline Ava12  Germany
So one answer to this old, but certainly very interesting thread would be the HB-DAC1704 from Borbely Audio?
in which direction did all those design ideas go?
Any update?
Greetz Ava
non OS pcm1704 hugobors Digital Source 12 1st March 2006 09:07 PM
Where to buy PCM1704? m_buzzi Digital Source 3 11th November 2004 12:53 PM
Pcm1704 hacknet Digital Source 5 11th April 2004 09:25 PM
PCM1704 DAC for sale Peter Daniel Swap Meet 11 6th July 2003 05:23 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Page generated in 0.10944 seconds (73.05% PHP - 26.95% MySQL) with 11 queries
