Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th September 2005, 10:25 AM   #1
buddha is offline buddha  United Kingdom
Default Laser diode output lands?
The service manual to my dvd player says I have to
"short-circuit the laser diode output land" on the drive before disconnecting PCB flexi-cables.
As per this picture:
Afterwards, it says I should then "open the land".
What are these "lands"?
Why is it necessary to short them if the unit is unplugged?
Finally, what does it mean to "re-open" them? Am I meant to leave them short-circuited whilst the board is removed? How would I do this?
Thanks.
Old 9th September 2005, 11:22 AM   #2
You should solder the pins together - check the photo I attached. Do this before you remove the membrane ribbon cable (if you can rich the lands with ribbon cable attached to both mechanism and PCB!).
The new mechanism should come with both of these lands already soldered. Install the mechanism, insert both ends of your ribbon cable, and THEN remove the solder from both lands.
Use the antistatic wrist band all the time and connect it to the PCB's ground - one that the ribbon cable and mechanism are connected to.
Good luck,
Extreme_Boky
Old 9th September 2005, 11:24 AM   #3
replace 'rich' with 'reach'
Old 9th September 2005, 12:14 PM   #4
Thanks, Boky,
What are these lands and why is it necessary to short them even if the player is unplugged from the mains?
Old 9th September 2005, 04:31 PM   #5
caoauto is offline caoauto  United States
It is probably they don't want you to damage the SACD or CD reader part because probably that cause my player can not read the CD or SACD now. As I recall there is another guy have the same problem even those the power cable disconnect but there is charge in the caps still there, and the purpose of sordering together is to sure it is discharging. But I am only guessing, because I am waitting for my schematic to come yet.
Old 9th September 2005, 05:31 PM   #6
Hmm, can't I just jumper these with a piece of wire and sticky tape?
Old 9th September 2005, 08:10 PM   #7
alfsch is offline alfsch  Germany
if iam right:
these pads are for static protection when handling or no connection, because laser diode is sensitive to static charge.
simply solder it together...this is a short at the laser and makes shure, you dont kill the diode.
Old 10th September 2005, 05:05 AM   #8
dnsey is offline dnsey  United Kingdom
You could, but tape is a pretty good static generator!
Just solder them - it's not a difficult job.
Old 25th September 2005, 02:56 PM   #9
kevinkr's Avatar
The solder link is to protect the laser diode from static. Using scotch tape or any plastic tape across those pads is a bad idea as the tape carries a charge as well.
Use a properly grounded anti-static strap and it is a good idea to use a solder iron with a grounded tip as well.
Kevin
Laser Diode Successor of SLD-104U for SONY ESPRIT KSS Series tiefbassuebertr Digital Source 23 28th April 2011 06:46 AM
CD Transport: Laser Diode Guru?? HELP!!! bear Digital Source 44 20th August 2009 06:40 PM
Laser Diode current for KSS 151A? beauty_divine Digital Source 23 18th April 2007 09:47 AM
red/green laser diode wanted Tekko Parts 0 3rd March 2006 06:00 AM
Teac VRDS-7 Laser Diode Check coliny Digital Source 2 4th February 2004 09:49 AM
Page generated in 0.10345 seconds (79.15% PHP - 20.85% MySQL) with 11 queries
