| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
hi, first of all im spanis native so i apologise for my english.
i was long searching for some solution to have good sound in my pc, first of all a found a 3way hifi active crosover 24octave full instructions to bould, but since my skill and none of the intrumentations necesary to adjust it, i can not make the proyec, then i surende to boy some solution, but there is not a desent solution at cheap price, no 3 independent way active crossover. Then i get to this idea wile searching 3way active crossover, to use the sound card and by software crossover each output, first i found the foobar2000 but in these only what is played inside it is crossovered, the i found the Kx proyect, as i understand it makes the work in the sound card, so everything is crossovered, did i undertud it rigth? so here comes my questions: #1 with the Kx can i do it like thise? http://xover.sourceforge.net/active_xover_setup.png #2 can i use only 1 sound card, or can i use 2 and more to create more outputs #3 in my sound card with foobar it since to cut the sobwoofer frecuencis, not leling it out or simpli dont suport the, with Kx can i filter the subwoofer so i only add an amplifier and a subwoofer speaker? thats all for now and thanks |
#22 |
PC active crossover :
Realtek HD audio(ALC892) Virtual Audio Cable ASIO4ALL Maize Studio玉米 FabFilter Pro-Q Sound Delay JustLMS |
| best soundcard for praxis and multi-channel PC XO | thadman | Digital Source | 0 | 19th February 2008 03:02 PM |
| Small multi-UcD for active speaker setup, what to do? | 4real | Class D | 66 | 20th February 2006 11:14 AM |
| Any soft to use a 5.1 soundcard as an active filter ?? | youyoung21147 | Digital Source | 0 | 5th February 2006 08:20 AM |
| Active XO using PC soundcard? | mr_push_pull | Multi-Way | 9 | 1st December 2005 06:31 PM |
| active crossover from a pc soundcard? | bser | Digital Source | 17 | 18th August 2005 03:19 PM |
| Page generated in 0.06517 seconds (73.17% PHP - 26.83% MySQL) with 11 queries |
