Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel RCD-9658X, convert from 230V to 120V?
Old 14th January 2007, 05:13 PM   #11
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Did you read my post at all ? I just tested the links to the manual and they work.
It's only audio. Member of the non modular PCB design committee
Old 14th January 2007, 05:34 PM   #12
TDWesty is offline TDWesty  Canada
Yes, I did read the whole other thread, and grabbed the manual, but it's for the RCD-865BX, not 965BX. I don't know how much difference there is, but I thought I would ask Rotel anyway...
Thanks.
Shawn
NAD 3125 & 3020 amps, 4125 tuner / Rotel RCD-965BX CD / B&O 2400 / Nakamichi BX-125 / PSB 70R speakers / BrianGT chipamp in progress...
Old 14th January 2007, 06:04 PM   #13
tubenut is offline tubenut  South Africa
tubenut's Avatar
Very little difference, mostly cosmetic......
Guillaume
Croak Audio Exploration
Old 14th January 2007, 06:51 PM   #14
jean-paul's Avatar
Sorry, I should have made that more clear.
Old 15th January 2007, 02:28 PM   #15
Wow, now this is what I call good service (a response within 2 business hours!) see below for the service manual.
Dear Shawn,
Please find attached the service manual for the RCD-965BX. We do still
have the button array available for this model, part # CS00011 and this
part is available for $14.48 plus $10 for UPS ground shipping. You can
order this part either through your local Rotel dealer, or by contacting
our parts department at 800-370-3740.
Best Regards,
The B&W Group
B&W / Rotel / Classe
The file is under the 10Mb limit, but attachment did not work... email me, (or Rotel) if you need a copy...
Shawn
Old 16th January 2007, 12:24 AM   #16
Ok, I've posted the RCD-965BX service manual in PDF form here, since it is too big for most email systems.
Enjoy!
Shawn
Old 19th May 2010, 04:07 PM   #17
mquinn is offline mquinn
Default power change
I have an Rotel and see exactly what you posted here - but it does not seem straight forward to how to rewire to 120v. I have two wires on 220 (blue) and 240b brown. Nothing on the 120v post. I pulled teh service manual from B&W - but they only show the picture - not how to convert. Any words of advice?
Thanks! M.
Originally Posted by Vidalgo View Post
Here is main input of RCD-971. the picture only I have:
No selector switch, but the board under plastic cover has wire mounting pins with clear marking how should be soldered or for inspection.
Very easy.
Don't plug power cord to outlet before opening!!!.
Rotel RCD-9658X, convert from 230V to 120V?Hide this!Advertise here!
Case: Naka RX-202 120V to 230V convert PaleRider Everything Else 3 13th February 2009 05:50 AM
Convert 110v to 230v input ? istari knight Digital Line Level 6 1st January 2009 07:41 PM
From 230V 3pin to 120V 2pin? jkeny Power Supplies 7 6th March 2008 05:32 PM
My new CD371-120V or 230V ZuMbAiU Digital Source 0 14th May 2006 04:24 PM
120V QSC PLX 230v conversion??? bOOgy77 Class D 1 5th December 2004 07:25 PM
