| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | |||||||||
I forgot to thank Doede for his answer, excuse my rudeness. I'll look into it as soon as possible!
I know, I'm insane.Quote:
![]() Quote:
I use it with good results ![]() Quote:
The only objective opinions that I can collect are the ones based on experiment and comparison... but wait a minute, that's subjective. I guess it's as objective as subjective can get Quote:
Thanks for the link.Later I will post some links I've come accross, maybe some could comment. Best regards, Calin Dorohoi |
#12 | ||||
and is tweakable. Other option: conserve your 2 ways as they are and build two big woofers two complete a fullrange system. I made mine with Eminence delta15 and 5-7 cm real wood panels, trapezoid shape , all for US$180.Quote:
That's why you only need a resistor load to choose your desired Vout (and taste, through different R types). The kit's stock max Vout is 1.6V Did I explained it well, Mr Douma? Quote:
I live in DIY/audiophile isolation down hereThanks God, this is the best Hobby in the world and the forum is great.Arrivederci Mauricio |
#13 | |
I have used several output stages, including opamps and transformers, but with a simple resistor always convinced me ... doede www.dddac.de |
#14 | |
BTW, TDA1543 does support direct I2S, wright? I'm too lazy to search the specs file It's just that my DIYer fever had a relapse when I saw the CDPRO-2M transport Regards Mauricio |
#15 |
Hi Calin
Concerning voltage regulators, have a look at this... Voltage regs.... I'm certainly not a pro, but learned a lot from this site's pages. As the aspect of why one regulator would by better than any other ? Consider this : every power pin on a dac, opamp, even discrete transistor circuit can be regarded as an additional input. Most opamps do very well in amplifying PS noise above a few kHz... HTH A8
A8 If 'I' knew what I was doing, life would sure be easier... |
#16 |
This info is superb...and wright on time for me!
I am indebted... Best wishes. Mauricio |
#17 |
Well, I built my 16*1543 DAC tower yesterday, for my DDDAC1543
I had to set again R load and bias R to obtain the 3.85VDC desired. For R load I choose 120R to match better with my active CX wich I use as preamp. The bias R is a multiturn variable resistor and it was difficult to settle this time. Maybe I'm on the limit of it. I also swapped a few wires to solid silver wich usually takes long to burn-in. Well, it worked at the first attempt I think my beginner's luck doesn't want to live me It's too late to tell but I noticed even more relaxed and natural midrange, with better soundstaging and instrument definition. What's next? I have to change the stock R to Riken-Ohm and must explore super-regulators for independent supplies. As I said, Doede's DDDAC1543 starter kit is a great project: there's no relation between the price paid and the high sonic quality obtained. Now, I'm expecting to build a CDPRO-2M transport wich probably will include a direct I2S connection to a TDA1543 tower. Good luck to everybody and enjoy! Mauricio |
#18 | |
Probably be a good topic for a separate thread, but maybe you've all hashed it out ad nauseum in the past. |
#19 | |
I hope your nickname does not reflect your mood tonight
I can asure you that it sounds very good, whatever may this mean to you. Maybe having 8 or 16 DAC's in parallel limits the drawback you mention. My max Vout must be around 1.4V now. Help needed, Doede
#20 | ||
![]() Quote:
| Hello and advice needed | jackpipe | Introductions | 1 | 17th March 2007 09:29 PM |
| Help and advice needed please.... | smoothbreed | Subwoofers | 1 | 5th February 2007 10:11 AM |
| Help/advice needed | jjs4028 | Multi-Way | 13 | 11th October 2006 10:16 PM |
| Advice on amp needed | HiLLBiLLY | Multi-Way | 1 | 12th November 2004 10:13 AM |
| advice needed | jimbones | Full Range | 6 | 9th November 2004 07:40 PM |
| Page generated in 0.16128 seconds (84.50% PHP - 15.50% MySQL) with 10 queries |
