| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Does anyone know where I can get a schematic for a USB to SPDIF converter, like the ones from empirical audio. Thanks!!! I like their concept but $500 is a bit steep. Preferably somethng that can plug into a Mac without needing drivers.
#2 |
The chip is the PCM2902 or PCM2906, works in win, Mac and linux without drivers, the schematic is on the datasheet.
You find also some schematics here in the Digital section of the forum. Bye, Paolo |
#3 |
I used the PCM2704. Very straightforward. Made a PCB (called the HAGUSB), which I was planning on selling. But instead just put the circuit onto the motherboard of my new DAC. Anyway, here's the schematic. I left off the headphone amplifier output stuff. Just straight USB to clean S/PDIF. Output is 75 ohm with 1.2:1 tranny.
Circuit is self-powered by USB cable, isolated from CD player via tranny. Windows XP (and I suppose Mac) recognized it as soon as I plugged it in. After 30 seconds or so of automatic configuration, my laptop was playing CDs through the USB port to my external DAC. No software. No drivers. No mess. Them folks at TI did a great job with this part. Here's my test board. jh
#4 |
One thing I have been wondering about these USB to SPDIF parts: what clock controls the audio data rate? In other words, does the PCM2704 pull the data from the PC so that the 12 MHz crystal in your schematic determines the data rate (and hence the jitter on the SPDIF) or does the PC push the data into the PCM2704, in which case the data rate is set by a clock in the PC (thus causing SPDIF jitter by passing jitter from the PC clock)? Or is there some sort of ASRC involved?
Mike "Never confuse motion with action." B. Franklin |
#5 |
It is very much ASRC. The USB side is sent in data packets every couple of milliseconds. Then sits idle until next packet. Not sure if it is push or pull. The USB data rate is fixed, the packet rate is variable. There is networking stuff going on, like other items on bus, acknowledges, re-sends for error correction, etc. The TI chip buffers the data and then re-clock it out at a constant rate.
Only way they can get the right output frequency is via some synthesizer onboard. I haven't dug into it deep enough to figure out exactly how they do it, or how sensitive it is to jitter or the xtal charateristics. Nothing depends on the clock in PC, except to make sure the USB data rate is close enough so that it can be received without too many errors. So asynchronous pulsed data in, constant data out. jh
#6 |
From the PCM2702 datasheet:
The newly developed SpAct™ (Sampling Period Adaptive Controlled Tracking) system recovers a stable, low-jitter clock for internal PLL and DAC operation from the USB interface audio data The same applies for PCM290x family (that has also the spdif input). |
#7 |
So how about sample rate?
How does Windows drive it? 32, 44 or 48 khz depending on source, or directsound based sample rate conversion? Is the Windows volume control working? If it does, possibly the sound is not 100% pure the source signal. (Some even say you never get more than 14bit if the Windows mixer is in play) and how about higher Fs and bitrate? 96/24? Thanks |
#8 | |
EDIT- I just noticed a catch, the SPIDIF is optical only so you might need a converter (I've seen them for $20 or so).
2012, our time is running out. |
#9 | |
USB Data is data, no clock is sent. Only a few bits indicating what the clock rate should be. Output S/PDIF embeds a newly generated clock with the data. I think the normal "sounds" of Windows is at 48k. That is, the chimes, clicks, bells, and other mouse & keyboard sounds. Only an audio CD is played back at the 44.1k rate. jh
#10 | |
![]() (click to enlarge) |
| USB to SPDIF converter | rokoko | Digital Line Level | 12 | 8th July 2009 07:19 PM |
| HagUsb or USB-SPDIF converter by NIE? | Kane Williams | Digital Line Level | 6 | 4th November 2008 10:50 AM |
| Another USB to SPDIF converter | Kane Williams | Digital Line Level | 0 | 10th October 2008 10:25 PM |
| GB of PCB's for USB->SPDIF converter at head-fi | Nisbeth | Digital Source | 16 | 31st July 2005 12:33 PM |
| which is a better spdif-to-cmos converter? | rlim | Digital Source | 4 | 15th June 2004 07:03 AM |
| Page generated in 0.10565 seconds (82.35% PHP - 17.65% MySQL) with 10 queries |
