Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
The mods never end, adding Goudreau's triplets
Old 23rd September 2002, 04:58 PM   #11
Jocko Homo is offline Jocko Homo  United States
Banned
Did you get any resonance from stacking two chips of different capacitance in the same form factor?
I made some measurements years ago that showed stacking smaller film caps on top of larger ones definitely caused resonance problems.
Harry: do you remember that one? You were there that day......
Jocko
Old 23rd September 2002, 07:10 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The mods never end, adding Goudreau's triplets Send a message via AIM to Peter Daniel
Fortunately I did it the other way, I put the larger one on top.
Anyway, how you check for resonances?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd September 2002, 08:59 PM   #13
Ren Hoek is offline Ren Hoek
Banned
Default Anyway, how you check for resonances?
1.First get a degree in Electrical Electrical engineering.
2. Go to work for a company with a 500MHz Network Analyzer.
3. Read the directiions for Analyzer in step 2.
4. Measure resonances.
I am pretty sure that is how Pete did it but I think his degree in Physics.
Sin Bin by Sundown!
Ren
Old 23rd September 2002, 10:59 PM   #14
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
OUCH what was with that..
THAT was mean..
Old 23rd September 2002, 11:02 PM   #15
I don't think it was mean. I just got what I asked for, unless he was not telling the truth.
www.audiosector.com
Old 23rd September 2002, 11:11 PM   #16
Banned
Default THAT was mean..
Acually I was having a bit of fun. This kind of thing is pretty difficult to measure and I was just trying to make that point. I believe they probably is some advatange to this approach and I bet money Pete did measurements pretty much as described since he is an RF and signal integrity expert. No harm intended.
Measuring supply noise with a 100MHz scope is a good starting point for most of use mere mortals.
Ren
Maybe some info at www.sigcon.com
Old 24th September 2002, 08:55 AM   #17
ftorres is offline ftorres
ftorres's Avatar
What about adding a high value ceramic 1206 or 1210 cap (4.7uF or 22uF) to the triplet, if you have room for it. I've made some measurements (no audio results yet), and found that these little chips do a tremendous job removing digital supply noise, when combined with such a triplet.
François
"Learning French is trivial: the word for horse is cheval, and everything else follows in the same way."
Old 24th September 2002, 02:33 PM   #18
I've seen your thread and this is what inspired me to do it. I just followed Goudreau's artcle and he didn't mention the other caps (4,7u). It might be interesting to add them later, when I get familiar with the sound and see for a difference.
www.audiosector.com
The mods never end, adding Goudreau's tripletsHide this!Advertise here!
Adding SPDIF and other mods to Yamaha CDX 480 mace1337 Digital Source 42 7th January 2009 05:52 PM
FS: 500mm projection triplets (pro) $130+shipping kellyinvestor Swap Meet 1 7th January 2008 03:57 AM
Copyright ©1999-2017 diyAudio
