| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 | |
The last question: BEFORE? after the transformer? Could you suggest a type and value? Thanks Riccardo |
#42 |
diyAudio Moderator Emeritus
At the input of the regulators ( = after the transformer + diode bridge ) please use low ESR types like Panasonic FC and after the regulators ( i.e. at the output of the regulators ) standard BCComponents or similar. I can not express it any clearer.
You can use low ESR types ( Panasonic FC/OSCON ) for decoupling the SAA and other digital chips of course. Just do not use them directly in the proximity of the regulators outputs.
It's only audio |
#43 | |
Ok, thanks, very clear. Curiosity kill the cat....i have now another question: do you think could be right change the value (more capacitance) for the new cap? In the 2 situation , after trasformer, and at the regulators output? For example, at the regulator output the standard value are: 47uF, 25V and 33uF 16 V. I could, in Your opinion, increase the value until 100uF? or greater? or this choice could be absolutely wrong, and leave too much emphasys to low frequencyes, or lower speed of the sound? Thanks again Riccardo |
#44 | |
First of all thanks, Jean Paul. I'll try and effctively sanyo os con after the regulator produces a reduction in high frequencies. Better 037. But know i have another question, please: about decoupling SAA and other IC. What do you think could be the cap's correct value? The same of the original bypass, wich are 33uF and 47mF and 330uF, with BCC037, or try a 220uF with OS CON? The cdp is a marantz cd40... Many Thanks. Riccardo |
#45 | ||
It's only audio |
#46 |
Please, can someone help me with schematic for Marantz CD-40 ?
tiberiu_vicol(at)yahoo.com replace (at) with @ tibi |
#47 | |
Example : http://cgi.ebay.fr/Marantz-Service-M...QQcmdZViewItem |
#48 | |
Hi Riccardo: Please let me know where you bought the transformer's output Royal Device, and how do you have connect it to DAC. I want to try it instead of any Op Amps. Many thanks for your help, Antonio |
| Modding a Marantz CD40 | joydivision | Digital Source | 32 | 11th March 2011 05:55 AM |
| Schematics Marantz CD40 please... | Lyra | Digital Source | 15 | 11th May 2007 05:52 PM |
| Marantz CD40 | Jiiim | Digital Source | 7 | 2nd May 2004 10:10 PM |
| Page generated in 0.11774 seconds (80.06% PHP - 19.94% MySQL) with 11 queries |
