DIY 5.1 decoder
Decoder is all about obtaining the sorround channel. This is where Dolby alone holds a monopoly.
So rather than jumping into making a complete decoder, I think we should put our heads down and try to come up with a solution to get the surround channel i.e L-R and remove the dialogue leakage.
Decoding the other channels is easy. Remove the dialogue leakage and you join the biggies with your own product.
bimbla.
Not gonna happen... BUT...
The only way to do this properly (especially for the critical listener) is to have the actual algorithms and do the decoding according to spec. As far as details regarding the DTS algorithms go, they are very tightly controlled intellectual properly. I work as a hardware engineer on DVD players which use DTS, HDCD and so on, and I don't have access to any of this information. Only the core technology guys who build the silicon hardware and write the microcode that does this stuff have access to the nitty-gritty details of how it's all done. Of course, even if I did have access to the details, I'd be under NDA and hence unable to disclose it to the DIY community anyway.
Such a shame, since I think it would be a tremendously interesting project to actually implement a DTS decoder or something similar in an FPGA or DSP. Exploring the educational option is probably the only viable option... I did manage to get Protel to donate a full copy of Protel 98 when I was still at university, so it goes to show that big companies can be relatively charitable if you're persistent and persuasive.
All is not lost for DTS decode, though. While you may not be able to build a DTS decoder itself, keep your eyes peeled for affordable new DVD players to hit the market in about two months which include full DTS decoding (hint, hint ;) ). If you find the right model, you'll also get some other nice audio features like HDCD and DVD-Audio playback... Given the cutthroat DVD player market, manufacturers are under great pressure to produce feature-packed units at a very low cost. You might be able to find what you want for under $300 in another month or two... I mention this, because there's a particular model (not yet released), which I did some hardware work on, and when it comes out I'll be lining up to buy one strictly for audio use (yep, you can bet I'll be modifying it too ;) ). If I happen to play the odd movie on it, well that's just icing on the cake!
Always remember kids... where there's a DAC, there's uncompressed, full resolution audio data...
Cheers! ;)
5.1 DIY Decoder
Dont get me wrong, buying is different and making something yourself is different.
If decoding in digital domain is difficult, WE can do it in analog.
Once the algorithm in analog is understood, WE can switchover to digital.
I need support from you people to convert my design idea in analog, to a DSP algorithm.
Do I have any hands up........?
bimbla.
bimbla, I don't see how analog matrix decoding, dialog leakage removal, etc, are remotely related to the decoding of a packetized discrete audio stream. Sure, you can create an analog matrix surround decoder, and you can port it to a digital system which operates on PCM data. There are some benefits to doing this digitally, but also some pitfalls.
Though this is digital, it is totally different than discrete decoding, and will not come close to approaching the quality of a discrete decoder...nor will it be useful in the design of such.
As others have noted, a somewhat complete GNU decoder implementation already exists. There are two opportunities for development here
1) Fix/improve the linux decoder
2) Port the decoder to DSP
I actually have a TI C6000 eval board for which decoder code exists, but TI will not supply the code without a license.
diyAudio Editor
Joined 2001
Oh no, thinking again
Your comment about the Soundblaster made me think that a good way to go on a decoder and/ or D/A A/D would be a DIY box with a power supply that mimics the power supply of a computer, but linear using transformers, caps etc. 5 and 12 volts?
Then you could use some of the pretty good pro cards available for A/D D/A
Also you could upgrade something like the Soundblaster as someone suggested. If you fry it they are cheap enough to buy another.Replacing componants might make a surprising difference
and people could report back their findings.
Then a Usb port for the computer to control it. I know there are outboard units already, but with this you could choose whats best for you and probably save money.
Also- the Soundblaster Platinum has a hand remote control which might do enough that we don't need computer control. I know this wouldn't be ultra fi but the component upgrade is worth a try I'd think.
I guess the trick is the Usb interface to control a card meant t o be in a computer.
Easier I guess would be a separate linear power supply, a separate box for the card and i/o connections, and a wide ribbon cable to bring out a pci slot from the computer environment. Actually that sounds pretty cool!! BUT is there a way to filter out and bad juju that originates in the box and travels through the pci cable (digital hash of some sort?) The cable could be shielded of course.
It would be extremely difficult to control a PCI soundcard w/o a computer. A better bet would be a micro motherboard with an available PCI slot...then just write the code for linux.
Bringing the PCI slot out of the motherboard would also be a treat...there are very rigid specs for the tranmission distances to maintain signal integrity.
If you want to toy with this, just buy an Extigy. It is relatively inexpensive and really is rather decent. However, I must warn you that I am unsure whether or not it is possible to tap the digital signals...I believe the soundblaster cards do not have DACs in the normal sense, which means there may not be a PCM stream to tap anywhere.
I do have an Extigy (some limited info here, althought the most interesting bit [DAC] is still awaiting good testing) and would be willing to do some quick testing for digital PCM signals if someone has some technical data on the Creative ICs.
DIY 5.1 Decoder
I was trying to say too many things at a time.
This is what I mean:
Surround sound decoder is unavailable in DIY form. Let us see how we can develop one.
Options: a) Analog Decoder b) Digital Decoder ('De-packetiser')
Option b gives best results since there is no encoding and decoding of channels during recording. Each channel has its own identity (is discrete). The problem is breaking into the closely guarded technology.
Option a might sound uninteresting, but is universal since all equipment will have analog Lt and Rt out channels. We all know how Surround channel (S) is encoded. So here is our best chance to decode it from Lt and Rt signals.
Lt-Rt gives S but tow more processes in the form of expansion and delay need to be carried out.Delay should be relatively easy. So it all boils down to suppression of leakage dialogue and simultaneously increasing the gain of the effects only.
These two processes can be done in analog domain or in digital domain.
So even when I say digital domain, I am still with Pro-Logic II and not Dolby Digital or DTS. Also, the output of such a decoder will have a max of 4.1 and not 5.1 channels.
bimbla.
Using a Soundblaster LIVE! 5.1 only not Soundblaster LIVE! can be used stand alone for Dolby Digital. First the designer have to find a PCI slot and the pin outs. Next he or she needs to select a processor. A microcontroller will not work here unless the designer uses many to divide up the work flow. Third, the designer also need to find a storage medium that is sufficient. Then, the designer needs a lot of patients to code both the processor(s) and the sound card to handle the sound decoding.
Soundblaster LIVE! 5.1 can output to analog from its sigma chip, so it is tapable. The analog signal gets directed to the 3.5 mm female plugs. The Emu chip that Creative uses is programmable to do just about anything that deals with audio. I'll write down what sigma chip model I have and then post it here tomorrow. Well its already tomorrow, so I'll post it in about 15 hours.
Yes, audio DIYers can design surround sound decoders. They just need to look in the right places. I have found many surround sound decoder chips.
What's wrong with just putting a dedicated computer with an SBLive card in it? You would have to perform a few modifications (n.b. you can mod a regular SBLive to a SBLive 5.1 by reprogramming an eprom) to extract the digital signals. In fact, you could probably just use one of the existing expansion boards that are out there (www.hoontech.com). The software to program the DSP is in the drivers already. The only "problem" is the internally 48kHz processing although I guess this matches Dolby Digital. The Audigy has the same 48kHz limit, but it might up/oversample it to 96kHz.
Computers are pretty darn cheap nowadays; we might as well use them.
-Won
PS Here is a useful link
http://www.digit-life.com/articles/livetolive51/index.html
Looks like the SBLive does some bass management. It would be cool if you could coax a digital crossover out of this thing...
Electro,
I could not find a single sigmatel chip that does either Dolby Digital or DTS decoding. They sell a bunch of multichannel codecs, but these are glorified DACs or MP3/WMA players at best.
They are useless for surround-sound decoding.
Perhaps I am missing something though--could you point out the chip you are so interested in?
maybe this isnt useful, but i have a small idea.
you mentioned using an extigy as a decoder? well, some motherboards have 5.1 decoding built into the mobo. for instance, mine, the IWILL KK266. its a pricey board, but i use it for my setup, and it works amazingly well. i am a critical listener, and it really sounds decent. (i personally use the optical to my stereo, and bypass the internal decoder). but, it will decode into 6 discrete analog channels, or output to SP/DIF.
costs around $150. might or might not help....
There's nothing wrong using only the SBLive! and a dedicated computer. Though it is easier to hook three plugs on the SBLive! 5.1 instead off an header from modified SBLive!.
Have a look at STAC9460/62. All it needs is a processor that outputs to one or three I2C outputs. For a simple design is to buy an OOPIC and use its virtual circuit feature. OOPIC can use either BASIC, C, or JAVA programming languages, so the learning curve should be small for the DIYer. The speed might be a problem.
OOPIC - http://www.oopic.com
Motherboards uses a switching power supply that ruins audio quality. There are other sound cards than Soundblaster LIVE!. TerraTec and Lynx Studio Technology are good sound card companies. However, I never heard the sound from either them.
Lynx Studio Technology - http://www.lynxstudio.com
TerraTec - http://www.terratec.net/ttus/default.htm
Electro,
I think you are missing the point with your sigmatel chips. Anyone can take I2C from a decoder and route it to a DAC...hopefully to a better DAC than sigmatel makes. What has people frothing at the mouth is the thought of getting ahold of a decoder.
Haldor,
That's intriguing. Too bad it is DTS only, but only $200 for silver!
All DTS decoders are DSP. Many audio DIYers don't know how to program. This is one obstacle they avoid or accept it.
The sigmatel chips is not good for producing hi-fi sound. Sigmatel did the hard part. All what the designer needs to do is add another stage to decode the 6 channel digital data and send it to the sigmatel chip. The BASIC programming langauge that OOPIC accepts will be easier for the designer. With the OOPIC the designer can program in virtual circuit mode with out being too confuse. The virutal circuit mode relates to digital gates. I'm not saying that sigmatel chips are great. They are great for starters. It is best to start small and then advance from there.
DAC or ADC are slow for analog (audio). Everybody should know this. If anybody can find a computer that has a switch rate of 1 picosecond. Please post a message here or e-mail me. Then we can talk about real digital sound.
