Removal of SAA7220
Hi there
I wanted to get a CD640 in non-os, it works, with Tent XO to Xin of SAA7220(pin11) and WS, CL , DATA from 7210 to 1541
I want to use this player to try and test periferal gear to select the best Dac's, try Tent clock vs Kwak clock, try opamps, discrete or tube I/V's and maybe more.
But when i removed the 7220 (to test if without 7220 give less pollution on PS) the player plays 5 minutes, stops and cannot read disks anymore. After some power-down time it starts again and same story again: no reading of CDs
I have put the XO in pin19 of SAA7210, and disconnected the transistor with collector on pin 19 and emitter to Gnd. The base is connected by a cap to +5V supply and a diode to Gnd.(When this transistor stays connected to pin19, the XO will not be recognized, no CD reading and the CDM is spinning fast)
What connection have i overlooked? Has it something to do with master/slave function of 7210 and 7220? Or is EFAB the problem? :confused:
Never seen such a transistor on the clock line. It seems to shorten the 7220 clock output at reset. Hope the clock is not damaged, but it stills seems to work.
Sounds like a powerregulator gets too hot and shuts down. Are you shure you still have the correct powersupply voltages on the chips? Maybe you made a short somewhere when removing the stuff.
Or it is just wear: bad connecting due to age of the soldering which appears when a component gets hot. Always check the powersupply regulators in older philips gear. Might be just that, triggered by working on the pcb. :)
Thanks for reply Guido.
Indeed this 640 is a very old and much used player, i used it every day 1 or 2 hours for 18 years now! Have a spare 660 at hand from marktplaats.
Solved in time a few problems already (regulator, connectors broken, 1 transistor) Indeed a chip gets i little hot, will check the regulators/voltages
The transistor looks like a muting device indeed, in the serv. manual are asteriks by the parts, so not all models have the transistor. The XO still works i guess.
Cheers:
Checked every voltage, also on the chips itself, all within normal range.
Reversed mods too: 7220 back, XO clock on 7220 Xin and restored clock conn. 7220 to 7210. Plays ok again after 2 startups, but after 10 min. again the 640 stopped and cannot be started, no disc recognized.
The 7220 gets awful warm (about 35 degrees) so this chip would be dead i think.
Have a good sounding standard 16 bit 304 mk2 also, and in the 10 minutes of comparison Non-os(640) and Os(304) my conclusion about non-os is: sounds good, gets out of speakers more directly, pretty detailed, more dynamic sound, better bass, but.... the depth in soundstage is overshadowed by the instruments on foreground. Also the non-os 1541 "stands on your ears" more, ears do the filtering, and they don't like that when they have to filter the whole evening(have experienced non-os for about a 1/2 year)
Second but.... my two daughters, one 4 other 6 years,
with the 304 they kept drawing paintings....
same disc in non-os player: they started to DANCE:smash: :smash: on the music........
So it could still be the XO (damaged by that mute transistor).
Try putting in the original xtal and stuff around it.
Got a scope to look at the clock line?
Otherwise try a digital meter: ~2.2V=clock, 0 or 5 is dead :D
As for the 7220, it gets hot indeed. Worked on my CD80 and i had it up side down for a while (powered on). At a certain moment i fixed the faults (powersupply, what's new). But the 7220 had died :xeye: Could have been the powersupply or it got too hot from being up side down:dodgy:
7220 won't get warm
It did get warmer then usual, so mor than 35 degrees i guess
Both the XO and Kwak give such values, no scope at hand now, a friend has two but is on vacation.
The 640 worked again with the Kwak on the 7210, then after 3 minutes dead again.
Lets try Jocko's freezing method. It is not a bad connection on wires, because it always happens after 5 minutes, its the uP-chip i guess, lets freeze this one first. Have no uP at spare so the the 640 will be for parts, also because i am getting tired of searching
7220 and almost everything is upside down in the 640, the project i am building for almost a year now will have the PCB's all with solder side down (four 1541's parallel with shift registers, still thinking with or without 7220. (640 would be a handy testmachine then, Jocko's I/V or passive tube I/V)
I have read somewhere here on diyaudio, he liked the sound of one 1541 more then 2 parallel, so my conclusion would be then that each of the 4 outputs should be buffered and then the voltage summarized together as voltages, this to reduce negative interactions of 4 1541 outputs.
Thanks Jocko & Guido for comments;) and sorry for the long story.
When I was building CDPs full-time, I only replaced one '7220. Lots of '1541s. One each radial/servo and photodiode chip. No micros. A few front panels on '582 machines that did things so strange I won't even attempt to relate. One CD-80 had a problem with the display. Worked, you just could not tell track and time.
Does that give you any more clues?
Jocko
I know... the saa8461p is not giving any signal to the drawermotor anymore since one time a voltage in reverse direction blew the output stage of the 8461 plus the motor-transistors, due to a broken connection. So have to move drawer manually now to load cd.
The 660 in not often used (less wear on disc clamp) and not tweaked a lot as i did with the 640, and the 660 still works(for now at least)
The 640 was my first bought cd player in 1987 from my sour earned $$$, much later tweaked it a lot but now it has become a sort of study-object. At that time (1987) i was a student and because i owned a CD player i was called a "decadent student"!
clock mute SMD transistor
Indeed between the 7210 and 7220, i have removed the connection from clock line to the collector, after i noticed the CD640 didn't recognize the XO, (cd spinned fast)
But still i think it has something around that transistor, or because when the power is off for a while, the 640 works again for about 5 minutes and stops again, so maybe a logic gate somewhere around the removed 7220 is floating and has to be connected to +5 or Gnd somewhere, but this is just a guess. It lookes like the uP misses something after some time. Looked in the serv. man. but can't find a clue.:whazzat:
Correction: MAB8461
Last night freezed the chips to minus 50, no chips dead:dead: When connected the bunch together and power on it plays and stayed playing! I remember last time there was a little crack in the flex print below CDM-2, i guess will have dismantle the CDM and look underneath it. But last night also the washing machine started rocking with a lot of noise....
The kwak 7 doesn't work yet, have to check this with a scope.
Afiac i like the unmodded CD304mk2 with OS above the slight modded non-os CD640 with 1541A, XO and some better caps.
So it seems to be better for sound quality to start with a good player(die-cast cabinet and CDM) and then modify it in a good way.
I have searched also the web for a 2nd hand Wadia Digimaster X32 Dac to hook on the 304 in the future, but at the moment still a little costly, and don't even think about the X64.4
