Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
True 75ohm RCA Type Plug Possible?
Old 2nd June 2010, 04:51 AM   #131
LuisMCP is offline LuisMCP  Spain
LuisMCP's Avatar
Originally Posted by Guido Tent View Post
Hi Dan,
Thanks for the feedback
Our first PLL had its' corner at about 3 Hz. Our current mixed mode PLL (Grimmaudio CC1) is at 30 mHz (miliHz) if I recall correctly.
Most DIYaudio people do not have microwave experience, and even if they had, jitter requirements for audio differ quite a lot from those for communication systems.
I have no clue abot the Wolfson approach, do you have a direct link ?
best
To Guido Tent:
You have an e-mail.
Old 15th March 2011, 11:10 AM   #132
carz is offline carz
Default more important to properly couple S/PDIF to receiver chip
Originally Posted by Extreme_Boky View Post
It is even more important to properly couple S/PDIF to receiver chip, using adequate PCB layout and adequate circuit / components, but this has been discussed at lengths here as well as "over there"....
Boky
Will it do any good if i mod a DAC by using, for instance a Canare RJ-R 75 ohm RCA female receptacle, and connect it using a 75 ohm coaxial cable directly to the receiver chip ?
However doing so will there be any impedance discontinuity at both ends of the internal coaxial cable solder joints ?
Will this mod make it better or worse ?
Canare Corp.: 75 ohm RCA Connectors: RCA Receptacles
Old 15th March 2011, 11:30 AM   #133
Default quad shield cable RG6 cable
BNC combination at both ends (that is 4 X BNC) works much better than 4 X RCA. In fact, 4X RCA was completely unpredictable and was changing characteristics (sound) with the tiniest little change in cable length…. Internal wiring (within the transport and DAC) should also be executed with coax cable.
I obtained the best results with 2.5m length of RG6 quad shield cable terminated at both ends with BNC connectors. Much better than anything else I've tried.
Another interesting thing: I use almost exclusive properly annealed pure silver ribbons as power cables, speaker cables and interconnects (and internal hook-up wire!) Sounds detailed and very fast - great for valves.... however, nothing matched RG6, BNC terminated, when it comes to S/PDIF.
Boky
What brand and model of quad shield cable RG6 cable did you use ?
Old 30th April 2013, 09:01 AM   #134
jefflin5168 is offline jefflin5168
Default 75Ohm RCA Plug
We can provide you a real 75 Ohm RCA plug to you. Are you interested in it?
Old 30th April 2013, 09:09 AM   #135
s3tup is offline s3tup
s3tup's Avatar
Which looks like BNC and mates with BNC only?
Then it's BNC...
The missing link between lead and gold in alchemist's world was BS and commerce.
True 75ohm RCA Type Plug Possible?Hide this!Advertise here!
Can I convert 200ohm analog audio into 75ohm? The Paulinator Analog Line Level 9 3rd August 2007 08:22 AM
WTB: 2.5mm plug to 3.5mm plug cable Relax Swap Meet 5 10th February 2007 12:13 AM
Re : BL type & GR type of transistor for Aleph-Ono Arion Pass Labs 4 29th January 2007 06:15 PM
Details of the 75ohm impedance of S/PDIF for short distances. Garbz Digital Source 4 7th August 2005 10:51 PM
Where to get a 25 pin plug? Jye Parts 5 14th February 2005 04:26 AM
