My dddac + some questions - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th July 2005, 10:30 AM   #1
revell is offline revell  Belgium
Default My dddac + some questions
Hi, this being my first digital project, that involves soldering,
i have some questions : (I attached a picture to clarifie)
- Is the orientation of the clock correct this way
- the 20 uf elco near the clock : is the + and - correct
Old 26th July 2005, 04:35 PM   #2
Default Re: My dddac + some questions
Hi
pin 1 is at the dot. Pin 4 is down, right. This pin is ground. Pin 5 is the output, upper right.
Guido Tent
www.Tentlabs.com
Old 26th July 2005, 04:54 PM   #3
pburke is offline pburke  Germany
clock sits correctly (there needs to be a wire jumper under the PCB to connect the pin under the corner with the "T" of the word Tent to connect to the positive lead coming from the regulator (the lower of the two long jumpers you have on top of the PCB).
The caps positive lead should also be oriented to the trace coming from the lower jumper, just the way you have marked it on the image. Or use some non-polar Blackgates and you don't have that problem ;-)
Peter
Old 26th July 2005, 11:19 PM   #4
guido is offline guido  Netherlands
guido's Avatar
One other advice, use some proper sockets next time for the ic's.
These cheap ones are
Gebruik die met gedraaide contacten (rond).
Safes you from fustration later
mvg,
GuidoB
Old 27th July 2005, 10:57 AM   #5
Ok thanks everybody for all your fast advice;
Now I can continue constructing the cooling tower
FS: DDDAC USB Only - Assembled jeff mai Swap Meet 1 27th September 2006 05:42 AM
Building DDDAC questions? suspencefull Digital Source 5 25th August 2006 09:09 AM
Building a Dddac questions? excetara2 Digital Source 22 14th July 2006 03:44 AM
DDDAC questions gchrist Digital Source 19 30th September 2005 05:43 PM
mains ps for DDDAC? rwagter Digital Source 47 28th November 2003 07:50 PM
Copyright 1999-2017 diyAudio
