| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am planning an external 8 x oversampling DAC, SPDIF input, based on CS8412 receiver, PMD100 Filter and a TDA1541A DAC.
Actually, I am preparing a block diagram about the mode setup and the interconnections of this three chips. As I am not an EE, I have now (at least) two important questions: 1. Is the interconnect between PMD100 and TDA1541A correct? 2. I dont know, where to feed in what frequencies from the XO clock. Just know, M0 has to be 1 to set the CS8412 in "slave" mode. Every help is very welcome! Franz |
#2 |
Do you have a PMD-100 ... and more to the point, do you have an extra?
#3 |
Sorry, I just have one PMD100 and I hope, it is still working. See here:
http://www.diyaudio.com/forums/showt...268#post683268 Franz |
#4 | ||
#5 |
Thanks for your answer, rfbrw!
I am still not sure about the frequencies, about the (simple?) math behind it Let's resume my actual understanding: I will set the CS8412 to fmt 1 (M0 = high), to have FSYNC and SCLK as input and feed them from a external clock. Is it correct, to derive 44.1kHz to FSYNC and 5.6448MHz to SCK? Will this result in 8x oversampling? Kind regards Franz P.S. Here a foto of the future enclosure, psu, input section and display: a burned out Classé DAC-1 (with additional fuses in the psu )
#6 |
FSYNC is Fs i.e 44K1Hz and SCK is 64Fs. In standalone mode the PMD100 will do only 8x oversampling.
#7 |
Many thanks for your input!
Now, I feel like having enough information, to design a pcb. Kind regards Franz |
#8 |
Can You send me Your circuit if it is ready. I also do have an unused PMD100.
#9 |
Hi
If You like oversampling that is ok but maybee You should leave the room for just 2x oversampling in stand alone mode PMD100?
#10 | |
| TDA1541A-S1 and CS8412-CP NOS for sale | Franz Gysi | Vendor's Bazaar | 4 | 3rd June 2008 05:02 PM |
| 4 sale: TDA1541A-S1 and CS8412-CP | Franz Gysi | Vendor's Bazaar | 0 | 22nd May 2008 10:11 AM |
| My last TDA1541A S1 and CS8412 | jean-paul | Swap Meet | 4 | 3rd November 2006 08:19 PM |
| WTB: TDA1541A and CS8412 | buddha | Swap Meet | 11 | 8th September 2005 02:23 PM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 07:18 PM |
| Page generated in 0.09441 seconds (79.67% PHP - 20.33% MySQL) with 11 queries |
