Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaraki Drive and DAC images
Old 8th March 2006, 12:40 PM   #41
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Originally posted by ash_dac
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Unless you are pro' on the pottery wheel it will take longer!
I suppose you could always house the dac in a shigaraki ceramic tea cup !
Storm in a tea cup?
Old 9th April 2008, 05:34 PM   #42
johnm is offline johnm  United Kingdom
johnm's Avatar
This review sheds further light on the inards used in the DAC:
http://www.sakurasystems.com/reviews/reviews13.html
In particular:
"...the Shigaraki DAC contains a grand total of only 20 parts: 7 resistors, 3 capacitors, 6 inductors, 2 voltage regulators, and 2 chips. Everything is soldered together on a circuit board that measures 1.25 by 1.4 inches... One of the Shigaraki's two chips is the Philips TDA1543T, a 16-bit dual DAC which its manufacturer describes as their "economy" model. The other is the ubiquitous Crystal CS8412, which serves as the Shigaraki's self-clocking input receiver..."
Hope this is of some help.
- John
Old 9th April 2008, 06:23 PM   #43
johnm's Avatar
http://www.geocities.com/rjm003.geo/...o/diy_dac.html
Old 9th April 2008, 07:01 PM   #44
johnm's Avatar
According to stereophile:
"20 parts: 7 resistors, 3 film capacitors, 6 electrolytic capacitors, 2 voltage regulators, and 2 chips. Of the last, one is a Philips TDA1543T 16-bit dual DAC, the other a Crystal CS8412 input receiver."
http://www.stereophile.com/cdplayers/800/index.html
This was written in 2003. Somewhere around 2005 they changed to the Crystal CS8414 instead.
- John
Old 7th May 2011, 09:39 AM   #45
Tax is offline Tax  Australia
The two regulators are from National Semiconductor LM7808CT (8V) and LM340TS (5V). I recently replaced both in my factory shig DAC
Old 7th May 2011, 10:25 PM   #46
- John
This is correct, my factory DAC has the CS8414
Old 5th September 2011, 04:22 PM   #47
Gobble is offline Gobble  India
Based on the many reviews online, this DAC is said to require a very good transport. I am curious about how it would fare with a dedicated home audio PC with a sound card like ESI @Juli and running foobar+kernel streaming with FLAC files? Or will only a $$$$ transport do justice ?
I am contemplating this DAC for its purported "virtues"
1. Of not causing sensory overload, focusing on the music
2. And I imagine - not providing what is ultimately a disjointed portrayal of music where we listen to the lows mids and highs distinctly in terms of their impact on our senses, react to and get distracted by the sensory load, but miss out on the flow and the whole picture (trees vs forest).
3. Supposedly brings out the musicality even in bad recordings (of which I have many). Actually the stuff I listen to there are few audiophile quality recordings. As is obvious 1 and 2 is useless with bad recordings.
Am I off the mark in my assessment of this DAC from my readings and without a listening test?
--G0bble
Old 7th August 2013, 05:57 AM   #48
Originally Posted by lohk View Post
Second the DAC opened:
Here the image does not reveal the complete secret, but a lot of details nevertheless. The pcb looks very much "47labs-style", a bit DIY too much, considered to the efforts of some of you here. It is a mixture of p2p and pcb, it has to be like that, I think, although some details (the blue wire!) looks like an afterthought.
The DAC uses a single regulator (a 7805 perhaps), smoothing caps are either non-existent or not visible. SPDIF input (with a carbon 75R resistor) goes into a CS8414 directly. The pll filter uses an elcap (or is it the smoothing cap for the digital supply side?). The ShagirakiDAC uses a TDA1543 not in the DIP8 case, but in the 16minipack smd size, recognizable by the 8 "outside" feet soldered together, although the exact number on the chipcase is not fully readable. Maybe the heat dissipation of this package is better the smaller DIP8 chip. Two 3k carbon resistors are soldered on top of the TDA, maybe the IV conversion resistors. Another stripped cap is visible, maybe one of the output caps.
That is more or less what I can see. Now it is up to you for conclusions and further analysis.
So does this thing not have a transformer on the input side of the spdif? I am considering the jkspdif mk3 usb-spdif convertor and it does not have a transformer on the spdif output for galvanic isolation. I thought one on the input side would help. What do you folks advice for this dac - Should I stick to a convertor with galvanic isolation only? Given the bad measurements described here 47 Laboratory 4715 D/A processor & 4716 CD transport Measurements | Stereophile.com I am quiet apprehensive.
Of course the measurements dont um "measure up" to the real listening experience. Its a nice natural sounding dac with no audible noise as displayed in the measurements. But I dont want this lack of galvanic isolation to be the proverbial last straw on the camels back which will fail to transport me to the promised heaven audiophools yearn for
Thanks for your advice.
--G0bble
Old 7th August 2013, 08:13 PM   #49
Lithium 675 is offline Lithium 675  Indonesia
Interesting, thanks.
Shigaraki Drive and DAC imagesHide this!Advertise here!
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 07:31 PM
Shigaraki Amp thoughts mirilaj Chip Amps 2 24th July 2007 11:11 PM
47 Lab Shigaraki DAC with Dumpty ps Manolo47 Digital Source 0 29th March 2006 02:47 PM
My GC ala Shigaraki.... sa_schulz Chip Amps 6 29th August 2003 06:46 PM
Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive kelticwizard Everything Else 12 22nd January 2003 03:34 AM
