Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
What is better sounding I/V con. ?
Old 16th July 2005, 01:15 PM   #21
Gasho is offline Gasho  Croatia
Gasho's Avatar
I will measure the "1M" resistor , I don´t think this is true feedback loop. On PCM 63 , pin 6 i current out , an pin 5 is offset
Old 16th July 2005, 01:45 PM   #22
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Do you have a source for PMD100?
Yes, I have, but just for one piece
I still try to get it out of this burned DAC board, out of a Classé DAC-1.
I will use the dremel, as I cannot unsolder it (litz wire and pump dont work) up to now...
Hopefully, it is still working! And I will use secondary fuses for every voltage supply!!!
Franz
Old 16th July 2005, 01:50 PM   #23
Franz G's Avatar
Looking a second time at the circuit: 1M will be O.K., as this is a parallel circuit to R307 (3.3K) and lowering the value just a little bit to achieve the wished higher gain for CD reproduction.
But one question still remains: what is the purpose of the caps C301/C331 in the feedback path using CD-mode?
Franz
Old 16th July 2005, 05:08 PM   #24
Franz G's Avatar
I looked a third time at the circuit and redrawed the essential part to understand it better.
For the gain calculation, it seems essential to look at the following stages, as the feedback is included in the first opamps circuit.
Franz
Old 16th July 2005, 05:13 PM   #25
Franz G's Avatar
Finally, I managed to get the PMD100 out of its original board:
It was no fun, this work, because I could not remove the solder in the through contacted board
Franz
Old 29th September 2010, 07:21 PM   #26
hcosborne is offline hcosborne  United States
Originally Posted by Gasho View Post
What I/V conversion on BB PCM63K gives more natural , and transparent sound .
Active (AD847) , or passive with high quality , precision resistor (100ohm) connected from current output of DAC to ground?
I am currently using a 10 ohms precision resistor on the current output of my PCM63K. The signal is fed into an instrumentation amplifier followed by an open loop buffer. The sound is quite good.
What is better sounding I/V con. ?Hide this!Advertise here!
Best sounding DIY SS amp trespasser_guy Solid State 73 24th April 2014 05:09 AM
Better sounding ECL86's Robyn_E Tubes / Valves 2 9th August 2007 05:05 PM
Copyright ©1999-2017 diyAudio
