| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Account Disabled
Howdy everyone,
I'm modify & develop valve I to V converter from Thunderstone Audio and would like to work with chip TDA1543. My schematic still use analogue filter RLC for smooth cutting edge treble control. I hope you'll like my Idea with complete PCB.It's use 175VAC/0.2A & 7.5 VAC/1A for rectifier.It's spec from Thunds... is V out = 2V Rms for digital full scale Z out < 400 Ohm (rising at LF) Z load > 10Kohm THD = < 0.02% (2nd Harmonic dominant) Freq. Res. 20Hz-20KHz +/- 0.3dB (no O/S) Component list Resistor ¼ W 1% R1,R9 1.69K R2,R10 1.8K R3,R11 100K R4,R12 330 R5,R13 51 R6,R14 180K R8,R16 1M R19 2K R20 499 R21 1M R22 2.4M Resistor 2 W1% R7,R15 22K R17 47K R18 3.3K Non polar capacitor C1,C6 6.8nF/100V C2,C7 1nF/100V C3,C8,C5,C10 0.47uF/250V C4,C9 33pF/250V C18 0.1uF/250V Electrolite capacitor C11,C13 100uF/400V C12 10uF/400V C14,C15,C17 3300uF/25V C16 100uF/25V Diode D1 1N4007 BRD1,BRD2 BRIDGE DIODE 400V/10 ZD1,2,3,4 1N4759A IC IC1 LM317T Mosfet Q1 IRF830 Inductor L1,L2 6.8mH Vacuum tube VB1 6DJ8/6922 Socket 9 pins miniature Transformer IN 220VAC OUT 175VAC/0.2A, 7.5VAC/1A Mail me if you havy any question
#2 |
Account Disabled
With single site PCB.
Use pin 6,8 from TDA1543 for input of vacuum tube I/V analogue stage. No adjust, No trim, No problem and resonable price for DIY. PCB is coming soon. Mail me if you have any question |
#3 |
Account Disabled
I can't create PROTEL file to PDF file by add printer in "ADOBE ACROBAT PRINTER" after my computer had crashed from some user.So if anybody want some PCBs please email me for them
Or somebody can help me please suggest me suddenly regard AHT |
#4 |
Hi
Very nice project. What about the implementation of 1.75mA current sink you've placed in the electrical diagram? You didn't specify any component for this purpose. Regards Maurizio |
#5 |
Account Disabled
1.75mA come from TDA1543 I think it maybe from Rload = 1.7/2.2k = 1.75mA.
Do you think about this idea with this picture? Regard AHT |
#6 |
May I ask why you are using coupled inductors for the anti-sinc filter?
Cheers Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
#7 | |
I think it is there for simulation purposes - i.e. it represents the iout of the DAC (that for a full scale signal IIRC is slightly more than 2 mA) Cheers Andrea
#8 |
Hi AHT
Are you sure about 2.2kohm load? Your calculation is wrong. |
#9 |
Account Disabled
3.85/2.2k = 1.75mA...ha ha ha...I'm wrong.
1.7V = Vrms of TDA1543 with I/V resistor. I borrow an inductor concept from Thunderstone Audio and you can use another way for anti-sync filter such as gyrator.Regard AHT |
#10 |
hi,aht
I think lowering the impedance of your I/V circuit to 1/2 is better,cause the output level of 10K-20KHZ is higher. |
| Analogue output stage | maxpou | Digital Line Level | 0 | 18th April 2009 02:48 PM |
| Help on improved analogue stage | p.heimpold | Digital Source | 1 | 17th March 2007 09:16 AM |
| TDA1540 analogue stage | dariusku | Digital Source | 2 | 9th September 2005 07:01 AM |
| cdp analogue stage tweak | ohynot | Digital Source | 2 | 11th July 2004 08:36 AM |
| Seperate analogue stage after DAC chip | Bas Horneman | Solid State | 4 | 8th April 2002 11:37 PM |
| Page generated in 0.10081 seconds (80.73% PHP - 19.27% MySQL) with 11 queries |
