Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th July 2005, 11:51 AM   #1
dillo is offline dillo  Italy
dillo's Avatar
Default phantom pcm 1732
Hello to everybody,
I have a NAD c542 which uses a Burr Brown pcm 1732 dac.
On the Texas Instruments site I could not find any info on this chip.
Does anybody have a data sheet of this *secret* chip, or does anybody know if it has any other name or reference?
Thank you very much.
Old 8th July 2005, 12:32 PM   #2
macboy is offline macboy  Canada
Try google. It's out there.
Old 8th July 2005, 01:37 PM   #3
richt is offline richt  Puerto Rico
hi
pcm1710,1716, & 1732 are almost electrical identical on info datasheet
(schematic).
nad c541 is a beatuifull unit to heavily mod and surpasses much more expensive units!!!
the clock is located on the dac not on the servo! so start replacing the clock with a good one 16.9344megs,eliminate the 2 transistor output mutes near the rca outs (that prevents thumps when powering & off) it can be replaced with an relay.
these 2 small tweaks will perform a way lot better than you can imagine.
later start changing caps.
good luck!
richt
Old 8th July 2005, 06:27 PM   #4
Franz G is offline Franz G  Switzerland
Franz G's Avatar
A good source for datasheets:
http://www.alldatasheet.com/
Including PCM1732.
There are several good mods available for the PCM1732 on the net.
One of the easiest is the "Swanson" mod: direct output from the DAC with good coupling caps and a 100R resistor in series to the output.
Disadvantage: lower power level.
Happy ears!
Franz
Old 11th July 2005, 05:37 PM   #5
dillo's Avatar
Thank you very much guys!
I found the datasheet, but I still wonder why Texas Instrument hides it. There are a lot of very good machines out there running this chip and they have an outstanding reputation! Furthermore HDCD is to me a very good technology, even if it is not very popular.
I think I am going to bite off those nasty muting transistor and maybe substitute them with relays. Any advice? (please) Are thei useful only when powering up the cd player with the amp on, or they serve also when the cd player enters/exits stanby mode? ( or play/stop?)
Richt, what do you mean that the clock is not on the servo? there is a clock (at least a crystal) on the main board.. It should syncronize both the transport and the dac, or am I wrong?
Sould I do any special to install a better one (e.g. LC XO, etc)?
Would you recommend one in particular?
Franz G, thank you very much, you built some appetite in my curiosity... but I think you've gone too far for my ability and understanding of the matter.
Maybe I will post you in the future, when I'll have more confidence with these issues
Bye and have a very good time!
Old 12th July 2005, 08:24 AM   #6
mpopovics's Avatar
Default PCM1732
24-Bit, 96kHz, Stereo Audio DIGITAL-TO-ANALOG CONVERTER With HDCD Decoder
This is the only DAC from BB, which includes the HDCD decoder.
This is not for commercial market, only OEMs can buy those chips.
There are several licensing rules applies (AFAIK, the HDCD technology and all licenses related to it owned by Microsoft now...).
That is why you can not find in product range and can not buy it.
Old 13th July 2005, 11:44 AM   #7
georgehifi's Avatar
Send a message via MSN to georgehifi
I have the PCM1738e in my Musical Fidelity A3.24, but it does'nt have HDCD, it' a 24/96 or 24/192 switchable. Below is 1/2 of the circuit as my scaner can only do A4 and it's A3. I'll do the other 1/2 in another post.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 13th July 2005, 12:07 PM   #8
georgehifi's Avatar
Input half
Old 13th July 2005, 12:12 PM   #9
georgehifi's Avatar
Power Supply
Old 14th December 2005, 08:42 PM   #10
ozone_stink's Avatar
Franz, I've Googled PCM1732 & mod and most of them concern the Swanson mod you speak of.
Would you be so kind as to point me in the direction of other mods or give me an abstract of what they are?
Thank you for your help!!
+/-15V from +48V Phantom Pilbromatic Parts 4 9th August 2009 05:46 AM
pcm 1732 current out or voltage out type? tubo Digital Source 2 12th April 2008 10:25 PM
48v phantom / resistor is way hot ! redrabbit Solid State 12 15th February 2006 08:14 AM
Using the phantom power Gabevee Instruments and Amps 2 29th July 2005 05:32 AM
phantom powering non-phantom mics karambos Instruments and Amps 8 3rd January 2004 09:21 AM
Page generated in 0.10237 seconds (77.86% PHP - 22.14% MySQL) with 11 queries
