Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th July 2005, 06:11 AM   #1
richt is offline richt  Puerto Rico
Default which is the best coupling transformer for a balanced 1 bit dac chip?
hi folks
i want to remove all op amps from this player and the da converter chip is a mash 1 bit da converter mn6471m
with an impressive sound. but i am looking to install a transformer
and adapt a tubed section tha i designed.
transformer should do balanced in /unbalanced out to drive
a 12 au7 mullard tube.
thanks
richt
Old 5th July 2005, 09:43 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Richt,
RaleighAudio uses the Lundahl LL1674
http://www.raleighaudio.com/passive_output.htm
I've also seen the LL1527 being used on the internet.
Good luck.
Old 5th July 2005, 10:39 AM   #3
thank you very much for your reply!
have you tried that design?
have you tried sowter & lundhal?
do i have to use some kind of low pass filter?
i am trying this design inside of a teac esoteric vrds10
the transport that wadia uses on their top priced transports.
i am having good results but i am looking for the optimal biaset
for the mullard 12au7.
thank you
richt
Old 5th July 2005, 11:22 AM   #4
I have the RAKK dac by RaleighAudio. The passive version. Works and sounds great. I don't think you have to use any filter because the transformer is in itself a filter. Lows and highs are filtered out by the tranformer...
I have not tried any other because the RAKK comes with the LL1674..I might try the LL1527XL just for fun one day...(but I can't right now because someone is evealuating my RAKK dac)
DRV134 replacment , better chip ,THAT1646 SE to Balanced gaborbela Swap Meet 6 5th September 2009 04:50 PM
Transformer Coupling Questions audio_moksha Tubes / Valves 6 15th January 2008 08:14 PM
6SN7 with transformer coupling DRC_YUN Tubes / Valves 1 26th October 2007 03:43 PM
Full balanced current (transconductance) chip-amp swak Chip Amps 3 8th February 2007 08:37 PM
Transformer coupling and output for SS mashaffer Solid State 1 17th May 2005 07:47 AM
Page generated in 0.07041 seconds (74.78% PHP - 25.22% MySQL) with 11 queries
