Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Planing my DIY transport
Old 3rd July 2005, 08:25 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Default Planing my DIY transport
to put an end to the endless search for a good CDP, I like to build a transport.
Base will be Philips CD960 because it uses CDM1 and is very fast finding tracks.
Design will be a toploader with lids sliding to the left and right to uncover CD.
The lids will be powerd by linear magnet actuators and sit on industrial linear ball bearing rails, all invisible both when lids are open and closed.
Display will be DLG7137 green alphanumeric:
TRACK 00 TIME 00m 00s
Here starts the problem, the segment drive signals have to be translated back to BCD code.
The CD960 measures not as good as other Philips players, hope this problem is not in the digital part...
Also I am not sure about the construction of the case.
Options are: fat aluminum bottom plate, steel bars like TEAC esoteric, sandwich steel-rubber(or other)-steel.
Also what is best ?, brass, copper or acrilic for a heavy base on which CDM1 will be mounted ?
Does a heavy puck any good ?
Any other suggestions ?
Old 4th July 2005, 07:46 PM   #2
revell is offline revell  Belgium
Hi Bernhard,
I've recently rebuild a dvd-player into a toploader as you intend to do
look here for some pictures:http://www.diyaudio.com/forums/showt...threadid=60135
The bottom plate is solid aluminium and the drive is mounted on acryl
What I also like to use for cases is DiBond. It's a light yet strong and sounddampening material.
Planing my DIY transportHide this!Advertise here!
DIY transport w/ CDROM drive vs player as transport dw1narso Digital Source 8 17th April 2016 07:14 PM
I am planing to build my first Gainclone and require your assistance... Tripmaster Chip Amps 35 24th March 2008 02:16 PM
PC as a transport SashaV Digital Source 17 16th April 2007 11:15 AM
planing a new amp. sr2002 Chip Amps 2 28th August 2005 03:15 PM
Copyright ©1999-2017 diyAudio
