| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
If you use the digital out of your CD than, in my opinion, you are better off with de DEQ2496 (behringer).
It's pritty cheap and without using it's 'could be better' analog section you have almost limitless correction options. You can easally store 64 memories with GEQs, DEQs, PEQs, limiters en stereo enhancers. I use 't, to shute up some anoying tendencies of my room and speakers. En i'm pritty pleased with it. I would never have been able to achieve that with other speakers or furniture moving. So improve your overall sound and correct your misbehaving recordings. Regards Simon |
#12 |
Do you know the difference between the Behringer 248-96: DEQ & DCX?
Either of the are probably the frontrunners Cheers |
#13 | |
If you're planning to use a PC as source, you can *probably* get equal/better results for less $$$ via either the built-in features of say winamp or foobar, or via VST plugins. However, I'm not sure how the usability would stack up. |
#14 |
Well one is a crossover with allot of equalizing power.
The other is a pure soundprocessor with a automatic room correction. And allthough not all do use that option i'm very pleased with it. The difference between the old and new versions. Brain power and highres ad/da & pcm capabillities. Thats all i know. |
#15 |
an XO + lot of EQ v soundprocessor with auto EQ
So DCX = DCX XO + lot of EQ & DEQ = soundprocessor with auto EQ?? |
#16 |
yep
The DEQ also has a realtime analiser (61 bands) Wich is very usefull but also fun to watch. "t seems de DCX is slightly cheaper. Download the manuals and see for yourself. They both use the same technic but 1 has 6 channels to compute and the other only 2. So i asume the DEQ does give you more processing power. |
| Easiest way to cut PCB's? | Dr.H | Parts | 38 | 25th May 2010 12:51 PM |
| Cleanest 12" high efficiency mids for the money? | BHTX | Multi-Way | 31 | 16th July 2008 08:00 PM |
| Easiest way to correct this dip? | JCoffey | Multi-Way | 12 | 11th June 2007 01:52 PM |
| cleanest drivers you've heard for <$30 | johnnyb831 | Multi-Way | 1 | 29th July 2006 05:31 AM |
| Page generated in 0.08593 seconds (74.87% PHP - 25.13% MySQL) with 10 queries |
