Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th June 2005, 12:35 AM   #1
neutron7's Avatar
Default How to fix SoundMax on board audio
Ok, so i got an emu 0404 to replace my old SB live and i ended up having to also use the onboard "soundmax" chip to play games, no trouble but it sounded horible even compared to the old sb live
so i did a rightmark RMAA test and discovered this:
Old 27th June 2005, 12:48 AM   #2
neutron7's Avatar
I spent ages searching for an equaliser in the driver, searched the web etc etc
I even found a few reviews complaining the "bass boost" can not be turned off. and similar RMAA graphs to mine.
anyways it turns out that you can improve it a great deal
its not audiophile or anything but now it is at least useable and bf1942 sounds normal again the soundmax even has EAX and all that stuff that games use.
the pictiure which will explain how.
1: open the windows mixer
2: select "properties" in the menu
3: make sure "bass boost" is turned on
4: mute the "bass boost" slider
now you will have the green response above and not the white one.
I have no idea why they would deliberately do something so awful to their sound chip! i can see adding a small boost at lower frequencies for crappy pc speakers but this is totally rediculous.
i believe this works for some earlier versions of soundmax (ad1885 etc) as well as the one i have (soundmax 4 ad1985 chip)
SoundMax Uninstalls croat47 Everything Else 2 6th January 2009 10:45 AM
New ST-70 Driver board from Blackburn Audio Original Burnedfingers Tubes / Valves 18 27th July 2008 01:28 PM
Mutliple VDC PS Board for Audio / DAC suds Swap Meet 1 6th June 2008 12:04 PM
Need Lovoltech LU1014D & F3 Audio Board number9 Pass Labs 0 6th October 2007 12:25 PM
USB audio board or kit? jmar Digital Source 7 27th July 2005 10:40 PM
Page generated in 0.07374 seconds (80.18% PHP - 19.82% MySQL) with 11 queries
