Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th June 2005, 07:27 AM   #1
xiaolong's Avatar
Send a message via MSN to xiaolong
Default My new design of AD1865NOSDAC opamp output
The AD1865NOSDAC, OUTPUT of my new design is an OPAMP
The TUBE edition of the ex- design of 1865 because the signal handle not good, I abandoned it, and afresh designed the OPAMP edition of 1865 NOSDAC.
Its LPF the part very is not good to do.
Now again my headache of is, if it want to hear to rise good to listen, then frequency demand from 14 KHZs start get downing, if to 20 KHZs start get downing, and that is what very not good to listen,
Part of and big contain good suggestion in the LPF?
I design the following diagram of the adjustment's LPF similar, this part of electric circuits spend me good long hours come adjusting to just do out.
www.audio-sz.com
http://www.audio-sz.com/UploadFile/2...1194429342.jpg
Old 10th June 2005, 07:30 AM   #2
xiaolong's Avatar
LPFThe LPF part is a nether diagram paper
www.audio-sz.com
Old 10th June 2005, 07:48 AM   #3
those Nichicon caps u used for your power supply, without the shrink wraps....what series of Nichicon are they? any data or info on them? have seen plenty of these around but did not try them since data is not available.
Old 10th June 2005, 11:20 AM   #4
georgehifi's Avatar
Send a message via MSN to georgehifi
what i want to know how the **** did you post half a meg of photos on one post when the limit is 104kb.
Let us in on how you did it.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 10th June 2005, 11:33 AM   #5
demogorgon's Avatar
Send a message via MSN to demogorgon
georgehifi, he didn't put the pic's on diy's server, he hosted them on another server.
cheers
marius
Old 10th June 2005, 12:49 PM   #6
Cheers George
Use that little mouse of yours, place the cursor on any of the pic...then do a right click, select 'properties' from the drilled down table....and then see the item 'address'...and u will see that the attachment links to the pictures' server. so the attachment actually links u back to the url of this storage server....not an actual attachment of files on this forum server.
Replace output opamp NE5532 wandelblu Digital Source 12 1st March 2008 04:18 PM
Opamp output resistor.. jethdub Chip Amps 3 21st January 2008 03:46 PM
OPAMP with Transistor Output polsol Chip Amps 11 20th February 2007 09:16 PM
Super output opamp!!!! voodoo? georgehifi Parts 14 6th July 2005 02:20 PM
OpAmp Pre-Amplifier Design Rachel Solid State 4 29th January 2002 12:32 PM
Page generated in 0.08694 seconds (75.58% PHP - 24.42% MySQL) with 11 queries
