| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#71 |
Quan,
How do you know that the laser assembly was faulty and is the only problem ? I may be wrong but I believe that the laser focuses first (lens assembly moves up and down) and then once focus has been found the disc spins to read the TOC. (Some other players spin the disc first and then focus). If the disc is spinning that means that focus has been found which is a good sign. Check that the sled can track across the disc properly, it may be that it can't scan to the centre of the disc. I also assume that you have already checked the power supply voltages and ripple ? Jon |
#72 |
Not wrong at all there Jon, you're spot on, the disc doesn't spin until focus is found... and that is much easier to do on a stationery disc. The disc is then "kicked" up to approx the correct speed at which point the data coming off disc is compared to an internal crystal clock. The disc motor servo then brings the disc speed up or down until its phase locked to the oscillator.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#73 | |
Quan |
#74 |
Hello, I have an Arcam 7SE that skips. I already have the replacement laser. Would somebody be kind enough toPM me Kora's PDF doc? Kora even?
This is the most detailed, musical player I have heard (i have limited experience) and would love to get it right again. Thanks. |
#75 |
Can I please get the (how to replacement KSS 240A PDF) Thanks you (jose.donna@sbcglobal.net)
#76 |
My Arcam 7 has developed a fault. It starts to play the CD but certain frequencies have a raggedness about them, the tracks also sound slightly slower in speed but the difference is very very slight. Also, just gently tapping the top of the case causes skipping, even jumping to the next track! Is this a worn laser fault? Perhaps someone could send me the pdf about laser module replacement, it would be most appreciated. (lez@ntlworld.com)
Many thanks in advance, Les |
#77 |
The CD's speed is crystal controlled so I very much doubt there is any issue there. If you want to prove it then play a test CD with tones and use a frequency counter on the audio output to check. No laser fault can alter the speed.
The KSS240 is dead easy to replace and could well be suspect although normally I like to prove optical blocks faulty first. The 240 had a problem with the lens suspension assembly I seem to remember.
#78 |
#79 | |
Please... i would like to replace kss-240a me too...
Can i have the guide on pdf ? Thanks in advance Quote:
| Arcam alpha 7 CD - replaced laser but still skipping.. | Greenderek | Digital Source | 6 | 29th June 2010 11:32 AM |
| Sony FH-B7CD / KSS-240A problem (for Anatech) | antidot | Solid State | 5 | 23rd January 2009 01:26 AM |
| Sony Laser Mech..Arcam | Rare Bird | Digital Source | 6 | 25th September 2008 12:43 PM |
| Which Sony Laser For Arcam MCD | Thomo | Digital Source | 3 | 12th September 2007 01:51 PM |
| Replace KSS-240A on a Sony CD player | MP | Parts | 1 | 15th July 2004 01:17 PM |
| Page generated in 0.09839 seconds (81.06% PHP - 18.94% MySQL) with 11 queries |
