Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
remove saa7030
remove saa7030
Old 16th September 2008, 10:36 AM   #91
lcsaszar is offline lcsaszar  Hungary
Yes, you need a pull-up for 14-bit mode.
Old 16th September 2008, 02:06 PM   #92
Aronier is offline Aronier  Germany
Now i have a problem, the CD150 doesnt has the SAA7000, it has saa7010, 7020, & removed 7030.
Is the saa7010 same as saa7000?
And what need the 7010 for the TDA1540 14bit?
Thanks.
Aronier
Old 16th June 2010, 07:58 PM   #93
rfbrw is offline rfbrw
Originally Posted by rfbrw View Post
In short,you reformat the signals into a form acceptable by a SPDIF transmitter, in this case a CS8402.
Bah! Total waste of time. A lot of work for truly mediocre sound.
Old 6th October 2010, 06:40 PM   #94
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Who knows the different between SAA7010 and SAA7011? go to
replacing SAA7011 in marantz cd63
Old 30th October 2010, 05:49 AM   #95
noyan is offline noyan  Turkey
Send a message via Yahoo to noyan
Default Philips CD104 with PCM56 dac?
I am wondering after non os mod of the CD104, if i connect an external dac with PCM56, is it work or not? I mean, on the datasheet of the PCM56, input frequency was specified as minimum 10mHz. CD104 quartz frequency is 4.2336 MHz. Does it make problem?
remove saa7030Hide this!Advertise here!
cx7933,cx7934,cx7935,saa7030 with tda1540 pengxy Digital Source 11 2nd September 2016 04:36 PM
NHT ST-4 how to remove tweeter ? Chilli6565 Multi-Way 0 22nd September 2008 04:35 AM
saa7030 removal help billbo Digital Source 12 11th August 2008 08:52 AM
Trying to remove RF jduffy Chip Amps 8 26th February 2007 11:36 AM
Plain CD304 service manual or SAA7030 application information Bernhard Digital Source 4 22nd March 2004 08:58 AM
