Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th June 2005, 07:25 PM   #1
maartentje's Avatar
Default Dac Question - Cs8412 ..... Pcm63
Hay Guys.
I want to build a DAC with a CS8412 or CS8414 and a PCM63.
* Is there a schematic with a CS8412-CS5842-PCM63?
* Is the SM5842 the same as a DF1704
* Is the SM5813 the same as a DF1700
Greetz Maarten
Old 7th June 2005, 07:05 AM   #2
maartentje's Avatar
any one?
Old 7th June 2005, 08:43 AM   #3
dddac is offline dddac  Germany
Default Re: Dac Question - Cs8412 ..... Pcm63
Originally posted by maartentje
Hay Guys.
Greetz Maarten
any one?
Sure have a look at my Site www.dddac.de
the sm5842 is totally different... and also better !!
take care
doede
Old 7th June 2005, 10:56 AM   #4
maartentje's Avatar
Thanks! yeah i like it but can i remove the filter selection?
Just a another question can i replace the pcm56 with a pcm63 in the schematic below?
thanks!
Old 7th June 2005, 01:56 PM   #5
Yes, you can replace it if you change the schematic first. PCM 56 and 63 are totally different, they are not pin-to-pin compatible, if you meant that.
Old 7th June 2005, 02:00 PM   #6
maartentje's Avatar
okay, but why are people using a DF1700 DF1704 SM5842 between a cs8412 and a pcm63 this is much simpler.
Old 7th June 2005, 03:17 PM   #7
Banned
Default WHY??????
Because a '1704 is cheap and easy to get. Emphasis on easy to get.
Jocko
Old 8th June 2005, 01:40 AM   #8
Fin is offline Fin
Fin's Avatar
Default SM584x
Does somebody want SM5842APT or SM5843AP1?
I have a few of each (brand new) for sale or trade............
Fin
Old 9th June 2005, 01:37 PM   #9
If your building a DAC like this , have a read of my
June 1997 Electronics World article about overcoming SPDIF
You will need to purpose modify a CD player to extract
DATA, LRCK ,BITCLOCK and using 74AC74 flip flops
clock each of these individual signals upon transmission from
the Cd player and reception at the DAC ie 6 flip flops
or 4 if you want to use the dual feature of these chips.
The aforementioned signals then feed the DF 1700
directly bypassing SPDIF altogther. recommended you
use a line driver such as from Maxim , the Max 497
to effect transfer as 75 ohm feeds.
It works spectacularly , but becomes a unique set up
making that CD player and DAC a tied combination
Its benefits are that SPDIF multiplexing is permanently
avoided. Cheers / chris
Old 9th June 2005, 01:47 PM   #10
Banned
I would not advise using AC logic, though.
Jocko
Cs8412 - Pcm63 Non-oversampling maartentje Digital Source 29 27th November 2011 07:02 PM
CS8412 question maartentje Digital Source 16 27th December 2004 05:14 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Page generated in 0.09729 seconds (76.18% PHP - 23.82% MySQL) with 11 queries
