| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Does anyone out there have a datasheet for the Yamaha YSF210 digital filter IC? I have one in a CD player of mine that seems to be faulty. All input and output signals appear to be correct with the exception of the word clock which feeds the DAC (this signal is at 0V). I don't know what this clock should be but I assume it is derived from the system clock. The left and right channel streams are ok and the mute function is operating correctly. Any information gratefully received! Cheers, Jon |
#2 |
Jon,
I have a PDF copy, Email me or enable your Email button and I will forward to you. Does you machine use DIL or a SMD version? Cheers, John
Life shouldn’t be take it too seriously, you will not come out alive anyway… |
#3 |
Hi John,
Thank you very much for your reply. I've sent you a private message. Cheers, Jon |
#4 |
#5 |
Purer,
I have emailed the datasheet to you. Jon |
#6 |
Hi JonHarrison
Thank you very much for your reply Apogee da2000 |
#7 |
the fever of DIY HI-FI will NEVER be cured !!!!
#8 |
What happens if this chip goes out I'm asking because I got no sound coming out of the analog stereo out but everything else works fine it's just those outputs and I'm trying to figure out what's wrong.
| Some information please | ivorthedj | Multi-Way | 2 | 18th June 2009 02:00 PM |
| amp information? | tadiam | Solid State | 0 | 1st December 2007 09:47 PM |
| Kef 104/2 need information | Serratoga | Multi-Way | 2 | 11th November 2007 06:06 AM |
| amp information | tadiam | Solid State | 1 | 3rd June 2007 09:21 PM |
| information on yamaha HiBit | Bernhard | Digital Source | 0 | 20th January 2006 05:05 PM |
