Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th May 2005, 05:23 PM   #1
Umberto is offline Umberto  United Kingdom
Default Arcam Alpha 5 Plus CD Player.
Please Help.
I have distorted audio output when playing my CD's, i've checked the lazer to see if it was dirty and it seems to be ok. After some further investigation I've also manged to check the +/- 25ve rail and they both seem to be ok. I susupect it's a problem with the D-A circuit.
Has anyone experienced the same fault?
Old 16th May 2005, 06:54 PM   #2
tubenut is offline tubenut  South Africa
tubenut's Avatar
Check all PSUs... But, it can be a dodgy DAC chip, on the Arcam 5 it is permanently powered up btw and I have seen 2 players with a faulty DAC. Gets worse the longer you play. After an hour or 2 of rest it seems ok again..
Old 17th May 2005, 08:48 AM   #3
Default DAC Chip. (Arcam 5 CD Player)
Thanks for your reply mate, which IC is it? I don't have a manual i'm affraid.
Old 17th May 2005, 09:09 AM   #4
pinkmouse's Avatar
Umberto, email Arcam customer support for a service manual, they are very helpful, and usually mail a pdf back within a day or so.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 17th May 2005, 12:10 PM   #5
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Umberto
I have here the complete boards out of an Arcam 5 player. The only fault: main tranny burned and no transport.
I got it to scavenge and to build my own external DAC...
So, what seems most suspect on this board, what I would check in your case: the two nonpolar 100uF caps near the output jacks on the smaller board. They sit fully in the signal path and they could be aged.
Should you receive a service manual, could you send it to me per mail? (franz.gysi@tiscalinet.ch, please subject "Arcam" or something like this (Spamfilter).
Should you not succed with the reparation, I could offer you my boards, but take it as your second chance
Kind regards
Franz
/Edit: I realized to late: my boards are not from the plus version and I don't know about the differences. I am very sorry! But I am quite sure, you will find the two grey caps, I mentioned. Check them!
Old 17th May 2005, 05:40 PM   #6
Franz G's Avatar
Boahh, I already got a service manual!
Many thanks, Martijn!
Franz
Old 17th May 2005, 06:43 PM   #7
Franz G's Avatar
Umberto
Here a picture of the DAC/Audio Board showing the mentioned caps (red arrows).
After looking at the schematics, this is the most possible reason for your problem!
After isolating the problem (you can try a lower value than 100uF, possibly loosing some bass, but the distortion should disappear), you could check, if the attached device (pre- or integrated amp) has some input caps.
If yes, you dont need the output caps in the player and you can replace them by a wire.
In this case, I may suggest you also to remove the output mute transistors (Q2/Q102) and the output resistors (R14/R114). See blue arrows.
Old 17th May 2005, 08:37 PM   #8
tubenut's Avatar
The DAC chip is the TDA1541A...
Old 17th May 2005, 08:46 PM   #9
diyAudio Moderator Emeritus
jean-paul's Avatar
Big chance it is the one causing the distortion......
It's only audio
Old 18th May 2005, 11:09 AM   #10
Default Arcam CD Player
Thanks guys for all your help so far I will keep you posted.
Arcam alpha plus cd player help Scrappydoo Digital Source 29 1st March 2010 07:31 AM
spare part Arcam Alpha 5 cd player paul_g Digital Source 7 3rd September 2006 09:06 AM
Arcam Alpha 5 cd player paul_g Digital Source 5 21st December 2005 10:55 PM
Anyone installed a TentLabs XO on an Arcam Alpha 5 Plus Player dewdrop Digital Source 13 29th March 2004 06:18 PM
Arcam Alpha 5 CD Player paulcurrie Digital Source 0 31st January 2004 12:47 PM
Page generated in 0.10027 seconds (77.54% PHP - 22.46% MySQL) with 11 queries
