| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 | |
No, John, its not! The ERROR CORRECTION is different, but the data is the same each time. That's the crux of the matter. There is a lot of redundant data on the disk, and if the dust particle is there, data from another frame is used to assemble the "dust" frame correctly. So, yes, the processing in each case is different, but you get the same data, each time. Without it, the CD could never been the succes it has been. It is a very robust medium. Jan Didden PS There is of course a limit to what can be corrected. If that limit is reached, error concealment is entered. But that is not what we talk about here, I assume.
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#22 | |
diyAudio Moderator Emeritus
#23 | |
diyAudio Editor
#24 |
Jan,
I have some understanding of error correction systems and the maths. My dust particle was for example only. Yes, the CD is very robust, but there is sometimes a lot of damage. Consider the situation where a scratch causes some diffraction, and the wobble of the disc is sufficiently chaotic that particular data is sometimes read, and sometimes not. In this case a CD player may sometimes correct or sometimes conceal. Perhaps it gets it right 60% of the time. If an the data is read many times with statistical correction, the chances are that the result will include the correct value. |
#25 | |
In the very early days of CD's I was privy to tests at a Japanese manufacturer of error correction tests on discs produced in Europe and Japan. We found error flags far more often on the Euro-discs. These were new discs. The errors were either manufacured-in or recorded-in. It meant some design changes to equipment to cope with this. I don't know how things are now, but even in the last 5 years I've heard of dust problems in manufacuring plants. |
#26 |
Well, it gets a bit speculative now. But let me tell you, a CD that needs error concealment is unlistenable! You will very quickly get frustrated and throw it out, or at least skip that track. The fact that the vast majority of CDs off the rack play perfectly in most any player, scratches and dust and all, is a testimony to the robust error correction algorithms.
Those Philips/SONY engineers knew their trade! I know a guy who worked at Philips, his job was to test third-party players to see if they conformed to the Redbook. Only then were they allowed to carry the well-known CD Audio logo. He told me that error free data reading is almost never a problem. Even the simplest, cheapest player delivered error free data. The problems were more with servo tracking under shocks, eccentric spindels etc. Jan Didden
#27 |
questions:
if errors occur during playback and the CD player needs to correct them, will the SPDIF output contain the corrected data, or not (see question below)? also, some "CD`s" with certain "copy protection" schemes are made with known errors a redbook cdplayer are supposed to correct without any loss of quality.how does this affect the data integrity of the CD when it gets scratches, compared to a real CD? |
#28 | |
Of course the output will have the correct data. You are not even aware of the correction process (as long as it can cope). You take a virgin CD, and play it. 100% correct data. Now you put a scratch on it, play it again, 100% correct data. You put on another scratch, play it again, 100% correct data. In all those cases, the raw data stream off the CD is different, but the data coming out of the digital output is identical. Jan Didden
#29 | |
Most CD players will interpolate, producing a "non-bit-perfect" output. Some will snap/crackle/pop. Your CD player might even lose tracking and skip if it's a bad scratch. I wouldn't mind seeing a professional CD player that will flash a LED whenever a CIRC failure occurs... |
#30 | |
so if I understand you correctly, it is not possible to create a copy protection scheme for regular CD-players that screws up the audio data at the SPDIF connector while retaining flawless playback at the analogue outputs? (not taking copy bit into account since it is easy to get around) |
| The 'Perfect' Box | wiredmonkey | Multi-Way | 6 | 13th May 2008 12:17 AM |
| My perfect pre-amp | TechnoMage | Class D | 0 | 12th December 2005 08:43 PM |
| Page generated in 0.11568 seconds (80.58% PHP - 19.42% MySQL) with 10 queries |
