| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
HI everyone,
I need help about internal wiring for my TDA1543 dac. What do You use for the digital and analogue wire inside the dac.... I would need something of very good quality but for not too much money. And if I could by a few meters not few hundreds of meters - small quantity please and where to buy- I would be very gratefull for the information. Thanks in advance and best regards daniel |
#2 |
another one
#3 |
Hi Sparkle,
Nice looking DAC. I recently built a Scott Nixon NOS DakKit. I used single strands from cat5 wire for the inputs and outputs. It is solid core copper and easy to use. I used some teflon coated silver plated copper for the power wiring from the battery. The teflon/silver/copper wire is cheap on EBAY. I stay away from silver on signal wires as it can be a bit bright on some systems. Both of these wires are cheap and sound good. Let us know how it sounds when you get it hooked up... |
#4 |
thanks mourip for the reply
Cat5 is nice sounding - no doubt about that but I have currently Harbour Industries M17/94-RG179 MIL-C-17. It is silvered copper (stranded). It is a good cable (better than Cat5) but I need something really better. Something that is a way beyond CAT5 and RG179 but on the cheap side (if this could be possible) and I don't have no more ideas (since I don't want to buy some Kimber Silver Streak and cut the wires from it Thanks again for the reply best regards daniel
#5 |
All this wiring effort for a 1543 dac? Are you sure you're not overdoing it?
#6 |
YES- I am absolutely positive about that- it is 16 bit dac but it could sound beutifully when done right. Right now my only problem is internal wiring
#7 |
Single strand TEFZEL ?
#8 |
Hi, I would like single strand - but what is tefzel, how good it is and where to find it?
regards daniel |
#9 |
Also ...... does anyone know where to find very good quality copper or silver bare(or within some enclosure) single strand wire around 20-22 awg. I would like to put it in some teflon tubing - maybe this would be good (something like audioquest I mean).
Suggestions? best regards daniel |
#10 |
Teflon coated single strand silver plated copper. As to where to get it, RS and Farnell spring to mind but I am not absolutely sure as I've always got mine from work.
| Internal amp wiring | Bama Slamma | Solid State | 1 | 2nd November 2006 06:45 AM |
| Internal wiring | Scribble | Chip Amps | 1 | 4th November 2004 05:52 AM |
| Internal wiring? | Mayday | Multi-Way | 22 | 5th March 2004 09:54 PM |
| Internal wiring | KenP | Solid State | 18 | 6th December 2002 09:59 PM |
| Internal wiring | 2Bak | Parts | 5 | 29th July 2002 09:37 PM |
| Page generated in 0.09584 seconds (77.28% PHP - 22.72% MySQL) with 11 queries |
