| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
May I know what does the 2 opamps do (between the active i/v stage and output buffers ?)
Can I remove them ? Will |
#2 |
You can't remove them, they form a LP filter.
#3 | |
Banned
#4 |
Am I correct in that they use a dual opamp with one half for
the IV conversion, and the other half for the output buffer? I knew recent MF stuff was of low design quality, but this ... |
#5 | |
All in all they used 4x dual op-amp for left and right channels !! This dac design really suck, especially on the PSU section where they use a 12vac and convert to a dual +/- 15 v regulated for the op-amp, thru the implementation of half wave rectification. will. |
#6 |
diyAudio Moderator Emeritus
I wouldn't remove them as they function as a lowpass filter with R101. This filter ( forgot the name of it but acts more or less like an inductor ) is connected in parallel with the signal and not in series as usual. It was used by many manufacturers in their higher range cdplayers in the past.
It could be a drawing error but normally the output pin 7 of U100b would be connected to the non inverting input at pin 5. A 100 k resistor to ground from pin7 to avoid plops when cables are disconnected and then the stop-resistor R107 from pin7 to output. I also fail to see why C109 has to be an electrolytic of 10 uF with R106 being 10 k when a quality film cap could have been used with a higher value resistor !?!? It could be that my theory is getting rusty, I know.
It's only audio |
#7 |
Looks like a resonant gyrator to me. It mimics a tuned circuit.
#8 |
Or to quote Burr-Brown " A frequency dependent negative resistance realized using a generalized immittance converter."
#9 | |
Pehaps the op-amp in question has a significant input bias current. |
#10 |
Aha, that could be the reason although I would think MF used FET input opamps as usual. Too bad, the type is not mentioned in the schematic.
From reading your post I just realised the filter topology was called GIC filter by japanese brands.
It's only audio |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 02:26 AM |
| Page generated in 0.11183 seconds (83.34% PHP - 16.66% MySQL) with 11 queries |
