Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th April 2005, 08:01 PM   #11
jdybnis is offline jdybnis  United States
OT: KBK, can you release anymore info yet on that ultracheap low-mass material for isolation platforms?
Old 30th April 2005, 02:07 AM   #12
KBK is offline KBK  Canada
That stuff has been distributed as a new product at the Hi-Fi expo 2005 in NY (on, right now!) , as of now. That's the Stereophile Home Entertainment Show, at the Hilton, I believe.
I've no idea as to the price, insofar as international pricing. Nor am I aware of how much it will be in Canada, but I suspect enough damping material for isolating one piece of equipment should be about $50 cdn, retail list price, ie, MSRP.
The entire Sterophile crew was in our room,and appeared to like the product very much. We brought enough to give every single magazine writer who walked into the room a 'set' of what we call 'gooeys'.
Old 30th April 2005, 02:14 AM   #13
I'm not an idiot, I am just being sure I'm not missing anything. I'd hate to charge right in there, and screw up a perfectly good Shandling SACD player. I do want my old Modded NAD 502 back, though..as it has one of my clocks in it and it walks all over anything else I've ever heard in the world of digital.
As for all those clock designs mentioned---it is so far out field of thsoe types, it is not funny. None of those types are even remotely close to what it is. . That's about all I can say.
as for the install..I could download all the pertinent tech manuals for all the chips, trace out the circuit in the shandling..and then go from there, but that's a total pain in the ***. I want someone to tell me what to do,as it's easier that way. Only because they've done this exact unit (shanling SACD) before.
I'll might call up Chris Johnson and and ask him what he does to these units, when he installs the clocks.
Old 30th April 2005, 02:29 AM   #14
Default Re: Let me see if I have this right.........
Originally posted by Jocko Homo
1.) You are designing a clock, of your design, and
2.) You want to patent it,
"WHY?", he asks.
3.) Yet you seem to be in need of assistance installing a generic DIY clock.
Am I missing something? Just curious.
Jocko
You are not missing anything Jocko. Not one thing. but, in my opinion, it is a good thing you are confused. That way, you aren't thinking about the situation.
I need help installing a generic clock, as I've never done anything exactly like this on my shanling before. The Shanling is a DVD/SACD drive unit, and has TWO clcoks in it. a 33 and a 27. Chris said the 27 is the one that needs replacment. SO..I look at the BB/TI PCM1738 chip. where's the clock in? I read the manual. no 27mhz. I'm frickin' confused. OK, whay would I want to go through a buch of useless crap and degrade the clock and then send that to the DAC chip?
Why does the DAC chip not support the clock I've bought? The 27mhz? Who in their right mind would not feed the DAC directly with a clean clock? I'm confused here. that's what's going on. why would I want a damned divider circuit between the clock and the DAC? Unless, of course, the DAC cannot supoort SACD and CD at the same time, via the one clock. only then, would any divider circuits make any sense. Who designs this ****? What planet are they from? the inefficent one? The brainless one? The mediocre one? Show me your smarts, instead. Not this.
STILL....if the freakin DAC's were properly designed, they would only need one clock. Obviously they are not. So I look to see if I can figure out how to get past that limitation. Sadly, I see no way, except putting the new clock right at the location that the original XO is. As Metallica said: Sad, but true. all kinds of damaged signal via long lines/traces/ribbon cables, noise, etc. Crap, crap, crap.
Old 30th April 2005, 03:33 AM   #15
Banned
If you are so "frickin' confused" (your words), then I find it highly amusing that you have developed some revolutionary new device. Looks to me that you are just shilling your products.
It is not the DAC architecture, it the is the overall architecture of "one size fits all" CD/SACD/DVD/whatever players that you need to kvetch about.
No, I am not confused........I know how that stuff works. One reason that I choose not to.
I share your frustration over "who designs this crap". Yes, it seems like it was designed by trained monkeys.
Maybe it was..................
Jocko
Old 30th April 2005, 05:10 AM   #16
Terry Demol's Avatar
KBK,
Before you go running to the Patent Office, I suggest you
get some phase noise measurements done on your clock
and see whether it actually has any measurable advantages
to what's already out there.
If you want something very good to compare to, check out
some of these clocks:
www.wenzel.com
You might also consider some info or books by Bob DeMatteis
http://inventors.about.com/cs/basics...aa041599_2.htm
Good Luck,
Terry
Old 30th April 2005, 07:46 AM   #17
Banned
Send a message via Yahoo to Elso Kwak
KBK, PCM1738 clock in is pin 7 (SCKI). What was the problem again?
Old 30th April 2005, 09:01 AM   #18
Banned
I can't see any problem installing the clock there.
If it's so complicated to install a clock on a PCM1738 dac (whick I already did on a Sony SCD-XA333ES), can I do that and get some of those new clocks for free?
Old 30th April 2005, 02:21 PM   #19
That's what I figured. I was going to,and am still going to download and print the tech manuals for all these chips, again. ug. I used the old copies to write on the backside..not wanting to waste paper. I took a quick look at the 1738 manual, and I could have sworn that I did not see any information on using a 27mhz clock direct into the chip. I'll look again. As I said, once again, I'll have to read the manual until I come to the point were I understand that the chip will work for SACD and CD on that single clock frequency. Digital is not my favorite.
From what I am getting here, inputing a 27mhz clock into the 7th pin is apparently the way to go. Now that --is-- simple. But, one has to read the manuals, look at what the chip is doing, look at what the the supporting chips do and how they are implemented and used, then come to the conclusion that the 1738 can be fed 27mhz on pin 7, and all will be well. As well...one would have to look at all that hardware and be able to understand clearly that this is the best way to do such a thing. Then ask themselves why anyone would do it any other way. I have to go through the whole process, I won't just blindly install the clock.
Please remember, I also have other hats/jobs to wear here,and I can do a quite decent job at 'digital', but it is not my desire to do, nor is it my favorite.
And Jocko, I apologize. As I said, I never should have started the thread(or more specifically, titiled it that way), and that's going to be my last comment on this specific component of this topic. Even considering.... your statement is not fit to reply to. Maybe see you in a 1.5 to 2 years, on this subject. Until then..nothing. No marketing **** either.
As an example along those exact lines: We, as a company (this particular clock thing is me,as an individual) finally published some product this week, ones that have been rumored for years. We don't release or publish until we are damned well ready to. Also the innovations are things that time does not easily overcome. Serious innovations. Ones at the base level, ones that are not sensitive to electronic or marketing changes. Hard physics. Not funky circuits or the like. This sort of thing allows us to sit on them and develop or use them..until the release (to market) time is right.
Old 30th April 2005, 03:57 PM   #20
jan.didden's Avatar
KBK,
Maybe it is just me, but I have no idea what you are talking about. Maybe we should forget about this threat and just wait until the glorious announcement of that fantastic invention?
Jan Didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Firstwatt Transformer Wars Tea-Bag Pass Labs 42 3rd April 2012 09:38 PM
Kwak Clock Design Project colonelkernel8 Digital Source 8 6th April 2007 04:28 AM
To superclock or not? dublin78 Digital Source 3 10th March 2007 07:22 PM
Word Clock Distributor design matrixtwelve Digital Source 14 7th May 2005 02:31 PM
Star Wars DVDs/VCDs JonmaTifa Everything Else 4 15th May 2002 06:03 PM
Copyright ©1999-2013 diyAudio
