| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi
My Denon DCD3560 suddenly has got a strange behaviour. It sounds like when a turntable plays scratched vinyls, the sound "jumps to the next groove". The display also jumps from let's say 2minutes 37 secs to 2 min 45 secs. What may be the reason and is there a DIY repair trick for this? |
#2 |
it does this on every cd?
#3 |
It is a very periodic error. The same CD an be played without errors and with, comes like at random.
#4 |
Does this only occour near the end of an ablum? It could be that the disc vibrates more at it's edge and the laser is having trouble tracking it. How old is the machine? It might need the lense cleaning or sometimes the laser assembly replacing.
...Well I put it all back together again and there was this spring left over and... |
#5 |
It is at least 8 years old, got it second hand from someone who had not used it for 3 years before I purchased it. I have had it for one year without problems, just started some days ago.
Happens in the first or middle or last tracks, no pattern. Lens looks clean and shining, no visible dirt or dust. I think I will let professionals look at it. |
#6 |
Some 3M laser head cleaning CDs might do the trick. It solves most of my situations like that. I normally let it play for about 4 minutes.
Hear the real thing! |
#7 |
Laser head cleaning CD???
Is it brushing the lens or how does such a CD work?
#8 |
Looks like some sort of tracking coil problem on the lens,think is time to do some alignment
#9 |
Clean the rod the laserunit slides on and the worm wheel as well and tip it slightly with silicone grease, it worked for me.
#10 | |||
| Teac Pdh303 C Cd Changer - Skips | scattycat69 | Digital Source | 0 | 12th August 2009 08:25 PM |
| Conrad Johnson DV2b skips | Tino_diy | Digital Source | 3 | 17th April 2009 07:14 AM |
| Philips CDC 935 always too sensitive - skips often | onyaw | Digital Source | 1 | 24th January 2009 09:27 PM |
| Aftermarket indash CD skips to bass | eRiCdWoNg | Car Audio | 5 | 8th May 2004 03:59 AM |
| Marantz CD63 skips CD-R's | Zombie | Digital Source | 17 | 10th December 2003 04:00 PM |
| Page generated in 0.09822 seconds (76.87% PHP - 23.13% MySQL) with 11 queries |
