Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th April 2005, 04:48 PM   #1
Default opamp questions
1)Ok, heres my question. Im swapping out the opamps in my dvd player which are currently 4560's. Im using AD8620's. Ive attached a image of the circuit. Shouldnt the PS decoupling be the same for the +8 and -8? They are using 100uf for the +8 and 100nf for the -8. Shouldnt these be the same value?
2)What would be the best value to use as decoupling with the 8620's?
3)What is the best way in this circuit to bias the 8620's into class A?
Old 25th April 2005, 05:16 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Hard to tell, there a whole supply system we don't see. maybe either the +8 or -* have regulated supplies? Is the load assymetric? That should be known first before deciding on improvements.
Class A can de done by a resistor or current source to one of the supplies, but I doubt it will be effective in this circuit. I would start to look at the electrlytic input and output coupling caps, they do much more harm than the opamp non-class A. And look to the whole circuit. What you show is just the anti-alias filtering. Is there an I/V upstream, or does it have a V-output DAC?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 25th April 2005, 06:04 PM   #3
The DAC is a V output. Would a pic of the power supply help? Its too large to attach, but I could email it to you. Let me know.
Old 26th April 2005, 01:31 AM   #4
Hi audiokid25,
+8v rail is probably loaded much heavier than -8V rail - this is why they used 100uF cap - pretty bad design, if I may say.
AD8620 might be too fast for your application and might emphasise the design or components in your player. Start with op275, proceed with AD826, but definitely try AD8620...
These OP's are already running their output stages in class A. No need to rape them further....
Extreme_Boky
A couple basic questions on opamp I/V NeoY2k Digital Source 6 13th November 2008 11:55 AM
Opamp line preamp questions Tolu Solid State 27 3rd November 2008 03:36 PM
various opamp questions traw Parts 5 13th October 2006 10:25 PM
dvd 2900 opamp questions... Htguy Digital Source 3 4th July 2005 02:19 AM
DRV134 Input Resistor & Opamp Output Questions Devil_H@ck Chip Amps 10 16th September 2004 10:24 AM
Page generated in 0.08764 seconds (74.73% PHP - 25.27% MySQL) with 11 queries
