Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th April 2005, 02:19 PM   #1
tonitze is offline tonitze  Singapore
Default 74ac02 unused input pins
Is it advisable to ground all unused input pins of the 74ac02?
Please advice.
Toni.
Old 20th April 2005, 03:03 PM   #2
macboy is offline macboy  Canada
Yes, but keep in mind that with both inputs grounded, the output will be high. Ground that, and you are asking for trouble. Generally, you can ground all unused inputs; leave unused outputs unconnected. Some logic types may have pull-up resistors on the inputs (or even the outputs) which is a consideration when determining whether you want to pull-up or pull-down the unused inputs. With AC series though, you should be fine either way.
Old 20th April 2005, 03:52 PM   #3
Banned
Default Yes, but...........
You would be better off avoiding AC logic. HC logic should be good enough; if not try VHC. Most anything but AC.
Jocko
Old 20th April 2005, 04:13 PM   #4
Thanks Jocko and Macboy. I will try out the VHC on my next clock circuit.
Toni.
Old 20th April 2005, 07:30 PM   #5
Toni.
Hi
Firts follow Jocko's advise. Then connect all unused inputs to Vcc and ground all unused outputs. After you've done that figure out why.
cheers,
Guido Tent
www.Tentlabs.com
Old 20th April 2005, 09:09 PM   #6
seoman is offline seoman  Netherlands
Ground all outputs
Ok I dig the part of connecting to VCC.
Aspecialy the old TTL ports use less power that way.
But i would never ever connect an output to a power line.
That's asking for smoke!
PLease explain
Simon
Old 20th April 2005, 09:35 PM   #7
Originally posted by seoman
Ground all outputs
PLease explain
Simon
Hi
The goal is lower inductance and damping in the ground circuit (off chip - on chip).
Why the smoke ?
cheers
Guido Tent
www.Tentlabs.com
Old 21st April 2005, 07:18 AM   #8
Well
If you make a mistake the chip will draw a lot of current from the supply.
Ok some people won't make a mistake but......
People reading this posts could think they always should do this trick.
And thats tricky!
Regards Simon
Old 21st April 2005, 12:03 PM   #9
Today just follow Guido's advice by connecting unused inputs to vcc and outputs to gnd. No smoke at all and the 74hcu04 runs at normal temperature. Improvement, wasn't sure but somehow sound smoother. Lower noise I guess.
Toni.
Old 21st April 2005, 01:52 PM   #10
BrianL is offline BrianL  United States
Guido, et al., I agree with seoman
I really question the suggestion to ground the unused
outputs.
It's always good practice to pull up all unused
inputs (with resistor, such as 1K unless the input is in
a gate you're using which might require pulling low)
If the unused output is naturally going low as a result
of your input setting, you still have the potential for
pulling current through the output and I don't see
that as a good or safe thing. I can't see how
connecting the output to ground will have any
salutary effect as the only think it can do is
cause more currents (hopefully DC) to circulate.
I also agree with Jocko to avoid AC logic (and "FACT' as well)
bel
z-5300 sub pins superxpro12 Subwoofers 3 7th January 2012 03:02 PM
Help with TP2050 Power Input Pins HolyGhostFire20 Class D 1 28th July 2005 04:36 PM
why multi pins ? 6SN7GT Tubes / Valves 9 10th July 2004 01:46 PM
crystal with three pins.. Marlowe Digital Source 4 16th January 2004 03:50 PM
lm pins theChris Chip Amps 0 26th April 2003 10:32 PM
Page generated in 0.09517 seconds (84.17% PHP - 15.83% MySQL) with 10 queries
