| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I ordered the board on Monday and it showed up this morning. It is
USD$299 direct from TI/BB. This was a way of "cheaping out" and getting a nice A/D stage for recording off vinyl. Burr-Brown seems to have put alot of good stuff into the demo board. The PCB is the size of a cd jewel case. It's two-layer very heavy glass epoxy stock. Connectors are 2x Neutrik XLR female and 2x RCA for line level in. Outputs are 1x TOSLINK and 1x 50ohm RCA. A BNC is also there for external clocking. There's a builtin clock onboard. Other nice things. The four OPA2134's are socketed 4-pin dips, so if you fry 'em, you can replace them. All other ICs are SMD. All electrolytics are Elna Cerafines (red and gold). PSU electrolytics are bypassed with what appears to be some kind of film cap - polystyrene I think. All the R's are 1/8W metal films. The PCB has two ground planes ; split right down the middle! One is analog ground and the other is digital ground. The control logic has its own 5V digital supply in. The A/D converter also its own dedicated 5V supply. The analog stage has private 15V bipolar power in. Quite abit of care was taken for a demo board. My only negative comment are the 10uF coupling caps in-line with the signal (you have to see the schematic). This may, or may not, be an issue - I will have to listen. Next week - time to build a small DC power supply. I'll let youknow how it sounds. I have a Sheldon Stokes Tube DAC board that I can hook up to the ADC's tail end so I can to A/D then D/A. -- Jim http://www.ti-estore.com/Merchant2/m...de=DEM-DAI1804 |
#2 |
link doesn't work. : O (
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
| Burr Brown PCM1701 | mpopovics | Digital Source | 1 | 19th September 2009 02:15 AM |
| Burr Brown OP-AMP? | joetama | Solid State | 4 | 22nd May 2008 12:53 AM |
| Burr Brown OPA655P | Karsten Sømand | Vendor's Bazaar | 0 | 7th April 2007 07:17 AM |
| FS Burr-Brown EVM-1702 DAC Board | kjunom | Swap Meet | 3 | 18th March 2007 10:12 AM |
| Burr Brown Pcm 65 dac | rickpt | Digital Source | 1 | 12th June 2006 06:33 PM |
| Page generated in 0.08477 seconds (66.44% PHP - 33.56% MySQL) with 10 queries |
