Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz cd-67se problems
Old 15th April 2005, 12:56 PM   #1
dod996 is offline dod996  United States
Unhappy Marantz cd-67se problems
I'm having problems with my cd-67se. when I incert a disc it will spin one way then spins the opposite way and then stop and the display reads disc. This problem happens sporadically. Some of the time it will spin and the disc will be recognized.
When this happens it does spin it doesn't seem to spin smoothly. When checked with a volt meter you can watch the needle oscillate.
Thanks in advance
Tony
Old 15th April 2005, 01:06 PM   #2
Extreme_Boky is offline Extreme_Boky
Hi Tony.
Have you touched anything inside?
Check the connections and clean the ribbon cable ends connecting transport PCB (located underneath the CD mechanism) and main PCB.
Good luck!
Extreme_Boky
Old 15th April 2005, 01:28 PM   #3
Default Marantz cd-67se problems
When I bought this cd player the seller said it was not working. It was doing the things I discribed and when i recieved it it worked fine for a few days. i tried all the normal things like cleaning the connections and it does the same thing.
Tony
Old 15th April 2005, 09:34 PM   #4
Hi Tony,
It might be time to search for circuit diagram and CRO.... Try to get both.
There's TDAxxxx IC that does servo control, it is clocked by ceramic resonator - check the clock signal here...
There's also main Xtal clocking DAC, check this signal (16MHz) as well.
Follow the RF path from the CD mechanism to decoder IC. There's an amplifier / low pass filter containing two transistors... Check here for a proper signwave signal...
The problem is in digital section!
Good luck
Extreme_Boky
Old 15th April 2005, 09:59 PM   #5
I was referring to 63se model. Yours is 67se. Difference is in servo control i think, however, you got the idea what to do...
Let us know the progress!
Old 15th April 2005, 10:47 PM   #6
I guess it's time to buy a scope!!
Tony
Old 7th May 2005, 03:31 AM   #7
dominik2410 is offline dominik2410  Austria
Hi Tony!
I had the identical problem with my cd-63se! I went for a new laser pickup and since I have changed the pickup my cd-63se works like new!!
I think the pickup is the same in the cd67se as in mine! It is called Philips cdm 12.1 and is sold on the internet for about 30-40 Euro. But go and check first.
Hope I could help you to solve your problem!
Dominik
Old 7th May 2005, 11:18 AM   #8
Thanks Dominik
I replaced the pickup and it still plays only intermittently and when it does play the disk doesn't spin smoothly.
Tony
Old 7th May 2005, 09:14 PM   #9
hanszl2001 is offline hanszl2001  Netherlands
Maybe I can help, underneath the laserunit is a small PCB with a TDA1302T attached on it , this chip causes the trouble, changing it will solve the problem (I've had exactly the same problem with my 67SE)
Old 8th May 2005, 12:07 PM   #10
I will try that thanks.
Any Idea were I can buy this chip in the USA?
Tony
Marantz cd-67se problemsHide this!Advertise here!
main ps cap upgrade for Marantz cd 67se crippledchicken Digital Source 2 30th June 2012 02:31 PM
Location Of C504 On Marantz Cd 67se crippledchicken Digital Source 2 5th May 2007 06:45 PM
link to schematic for marantz cd 67se? crippledchicken Digital Source 2 17th March 2007 03:45 AM
marantz 67se problems JZatopa Digital Source 2 19th October 2006 05:24 PM
What's a marantz cd-67se worth? elizard Digital Source 12 13th January 2004 12:08 PM
