| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi
I am replacing the opamps in the output stage of my Arcam Alpha 5+ I am going to start with some AD825 though i also have go samples of AD8065 and AD8610. What bypass caps values should i use for these? Fil |
#2 |
What bypass , on power supply or output?
For output you can use 4.7uF high quality polypropilen cap. |
#3 |
Hi Gasho,
No i was think of power supply actually. They are going to fit into Brown Dog adaptors and i have heard that i should do bypass to ground on V+ and V- and also have a bypass caps from V+ to V-. But for these opamps i cannot find what values to use. Any ideas? Cheers man Fil |
#4 |
[QUOTE]Originally posted by filholder
[B]Hi Gasho, No i was think of power supply actually. They are going to fit into Brown Dog adaptors and i have heard that i should do bypass to ground on V+ and V- and also have a bypass caps from V+ to V-. ------------------------------------------------------------------------------------ You will be amazed what 0.1uF npo caeramics (expensive) between V+ and V- will do for the sound! Try it. |
| Cathode Bypass in a PP Output Stage | CLS | Tubes / Valves | 8 | 15th July 2008 05:32 AM |
| N.P. Caps for Osc Output stage | Zero Cool | Everything Else | 12 | 15th June 2008 07:43 PM |
| bypass output stage in cd 6000 ose | Robi Medvesek | Digital Source | 6 | 19th July 2004 07:36 AM |
| cathode bypass in PP output stage? | RichJones | Tubes / Valves | 23 | 31st October 2003 09:30 PM |
| Page generated in 0.07039 seconds (75.28% PHP - 24.72% MySQL) with 10 queries |
