Strange problem with Clock Strange problem with Clock - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th April 2005, 11:09 AM   #1
AnthonyAsh is offline AnthonyAsh  Germany
AnthonyAsh's Avatar
Default Strange problem with Clock
Hello!
I installed and run now Hoer Wege master clock on my Rotel 991.Everything is ok,resolution is increases.But I have one problem.Looks like I have now too much highs.
I sended email Stephan,he told me running time for clock is around 3-6 days and all will be ok.I put it on replay mode for 4 days,still this problem exists.
Do you have idea why,and how I can fix this problem?May be clock is bad?Or may be I need to find chinch cable to correlate it?
Sleep of sanity create monsters
Old 29th April 2005, 09:32 AM   #2
Vidalgo is offline Vidalgo  Israel
Did you have any other mods?
For example, if you replace opamps to higher-speed devices, sometimes it's lead to unstability problem at signal transients. It sounds like "bright" highs.
You need a good scope with low-capacitance probe to check it, and a test disk with square-signal, any reasonable frequency is OK. (Be careful - turn off power amplifier before applying this test!!!). At opamp's outputs, observe waveform around signal transient - if any significal ringings are present, that's is the answer.
Old 29th April 2005, 09:41 AM   #3
AnthonyAsh's Avatar
Hi Man! Are you Vidalgo from hi-fi.ru? .My nick on this forum is Audio Spirit
Actually I found source of problem ,it was not clock at all,but some capacitors in power supply.I fixed it already.Thanks for reply!
Old 29th April 2005, 11:21 AM   #4
I use my nick at each accessible network place, just for life simplicity.
I remember your posted story about caps replacement, did it really harsh sound at highs so much?
In my CDP, original HCU04-based clock was replaced with PECL-based clock, and there is good audible improvements. But I say "original", when its schematics is properly tweaked, sound differences (compare to PECL) becomes neglible. The goal is to save original pcb layout, without "glued-on-air" components.
Old 29th April 2005, 11:28 AM   #5
AnthonyAsh's Avatar
It is not related to my caps replacement (elna vs. BG).It is another story.I put Audyn Cap 0.1 uF between +- capacitors in main analog supplies.It gives me some effect of "clear voices",but also effect of "high highs volume".Removing this capacitor brings all in place. I actually have right now very optimal sound,I even didn't opened my Rotel for over 2 weeks!.Funny
Strange problem with ClockHide this!Advertise here!
strange hum problem zeus_threat Solid State 8 18th December 2007 02:55 PM
strange amp problem!!! moonchild Solid State 23 14th January 2006 12:05 PM
Denon 2900 strange clock behaviour D.A.R.R.Y.L. Digital Source 9 25th December 2005 11:26 AM
Strange problem with amp lumanauw Solid State 10 12th March 2004 12:59 PM
Copyright ©1999-2017 diyAudio
