| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 | |
Does it need a hardware programmer ? I have never played with any PIC , gate array , Pal or Gal or whatever ![]() What is best to substitute lots of cmos logic like counters, flipflop, gates... ? Easy programming, low chip and programming-hardware cost ? |
#22 |
Most CPLD's are ISP (in system programmable via JTAG interface) and SMD devices (all?) but some packages are user friendly
#23 | |
1. Some free software available from the likes of www.altera.com www.latticesemi.com www.xilinx.com All software options above allow schematic entry and unless you plan to move on to FPGA's, DSP and the like, I would not bother clouding the issue with whether to opt for VHDL or Verilog. Unless you are competent in hardware design using a HDL would just be a distraction 2. A download cable needed to program the CPLD in situ. You can buy or make one. 3. A suitable device. As a beginner I'd steer clear of exotica like MAX2, Coolrunner2, XPLA3, ispXPLD etc. They either come in very user unfriendly packages or run off 1.8/2.5/3.3 volts or both. Go with something like the 5v XC9500 or the 5v MAX7000. In this case, given the number of pins required I'd go for gmarsh's XC9572 in 84pin PLCC package. Sorry no DIP, dude. |
#24 |
If You want replace logic circuit with lots of gates like TTL's CPLD is great solution and relatively cheap if to take under attention PCB board space savings and its proper design , power management system , noise added by logic to other electronics components on the board .You can reprogramming it like classic EEPROM/Flash device ( 10000program/erase cycles- 10 years program retention)It also allow to logic level conversion (one power suplly for core ,other for i/o)
#25 |
#26 |
#27 | |
DAC71 nicely fits the PCM53 socket but got visible nonharmonics. |
#28 |
Of course it is early iteration of this converter ,look at signal ldac it is inappropriate ,it should be one bck pulse for load internal latch data to output , and for proper load to internal latches it should stay low for remaining time to next load ,I fixed it recently .So You will also need simulator ,and some knowdlege how to write testing stimults or good and easy to use waveform maker like online Timing Tool
Regards |
| 6AS7 Parallel Feed Amp | lcsegeng | Tubes / Valves | 7 | 9th August 2008 02:17 AM |
| Isolating parallel feed amplifiers | neazoi | Tubes / Valves | 6 | 24th July 2008 10:51 AM |
| Adding a parallel feed on DRD | eeyore | Tubes / Valves | 1 | 11th July 2007 04:57 AM |
| Magnequest B7 parallel feed transformer for sale | MiaTele52 | Swap Meet | 3 | 16th January 2006 03:42 AM |
| Parallel feed OT | Bas Horneman | Tubes / Valves | 25 | 12th February 2003 02:07 PM |
| Page generated in 0.08588 seconds (80.89% PHP - 19.11% MySQL) with 10 queries |
