Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th April 2005, 12:27 AM   #1
rmihai is offline rmihai  Canada
Default Replace op-amp in CD-player
I need your advise. I want to replace an op-amp Njm4580 in my cd-player and I don't know which would be the best solution.
This op-amp is having a single power suply.
http://www.ampslab.com/PDF/njm4580.pdf
From Analog Devices or Burr Brown, what it will the best?
Thanks a lot
Old 16th April 2005, 09:31 PM   #2
maxlorenz's Avatar
Hello:
Probably I know as little as you about this but I think you first have to tell us what kind of package outline is your 4580 and try to find a diagram of your output stage.
From here I suspect 4580 has different pin configuration than 2 of the most popular opamp for upgrade: AD825 and OPA627.
Hope this helps.
Mauricio
"DIY or DIE"
Old 17th April 2005, 11:27 AM   #3
drews is offline drews  Italy
4580 is a double op-amp and Opa627 and ad825 are single op-amp. You can use two opa627/ad825 for channel or replaced 4580 with Op275 (double op-amp).
Old 17th April 2005, 12:42 PM   #4
maxlorenz's Avatar
...so you'll have to use an adaptor module to fit two opamps, like this (type 2):
http://www.referenceaudiomods.com/Me...ry_Code=OPAMPS
I'm concerned about pin configuration but here they say that type2 is good for NJM4560 replacement and I think 4560 has same pin configuration than 4580. Am I wrong?
Good luck
Mauricio
Old 17th April 2005, 12:44 PM   #5
maxlorenz's Avatar
Default Sorry:
I meant if you still want to use the single opamp versions
M
Phillips CD player - can I replace a PCB pushbutton switch? rwtomkins Digital Source 27 24th July 2008 01:25 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
Replace KSS-240A on a Sony CD player MP Parts 1 15th July 2004 01:17 PM
Replace opamps in Philips 963SA sacd player Ed Fallon Digital Source 0 11th April 2003 04:00 AM
Stand Alone CD Player vs. DVD Combo-Player Tom D Digital Source 0 2nd January 2003 04:08 PM
Page generated in 0.07708 seconds (74.27% PHP - 25.73% MySQL) with 10 queries
