| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
Indeed it is a different issue. While recording a cdr you may introduce jitter at both the extraction and recording phases and i've heard many claims that cdrs can sound better than original cds because of reclocking the data to a better clock, but this admittedly has not been my experience. Jitter due to the spdif interface simply means incorrect separation (in time) of clock and data from the multiplexed stream. Don't forget that error correction on music cds is certainly not as good as on data - there is simply less error correction code in order to leave more room for music.
cheers peter |
#22 |
i look scematic use IC 555AP6,555IR22,and 555ID10..................
what substitution that part because i am very diffcult get that component............ sory my english........... regards rio |
#23 |
74LS245AN (OCTAL BUS TRANSCEIVER NOINV)= ÊÐ555ÀÏ6
74LS373 (OCTAL TRANSPARANT LATCH) = 555IR22 74LS145 (BCD-DECIMAL DECODER DRIVER)= 555ID10 good luck |
#24 |
very thanks mr.ditter
u information very help me...... |
#25 |
heloooo mr.diter
i look u cd rom controller have facilities cd text but u give Hex file not have function cd text.... and i see u give source code in yours web site and i see at modul/function read cd text but is empty...... can u give source code read cd text function.............. sory my english.... regards rio |
| Source code for generating a pink noise | Calebay | Everything Else | 2 | 15th September 2006 03:44 PM |
| Circuit simulators with microcontroller code | rtarbell | Everything Else | 5 | 4th February 2006 09:22 PM |
| elf/eas controller source | masterp2 | Multi-Way | 2 | 24th June 2005 01:01 PM |
| Page generated in 0.07276 seconds (69.89% PHP - 30.11% MySQL) with 10 queries |
