Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th April 2005, 11:27 PM   #1
Default Saa7000
Has anyone got a copy, or a pointer to a copy, of this datasheet? TIA.
Old 7th April 2005, 11:35 PM   #2
TDA1540 is offline TDA1540  Netherlands
TDA1540's Avatar
got it.
390kb.
Old 7th April 2005, 11:38 PM   #3
Can you post it to rfbrw at clara dot co dot uk. Thanks.
Old 7th April 2005, 11:47 PM   #4
Got it thanks. Its for SPDIF from a CD104.
Old 8th April 2005, 12:09 AM   #5
TDA1540's Avatar
hush!
Before you know,they all want a 104!
Old 8th April 2005, 12:50 AM   #6
Well they can't have mine. I've got two and I'm hot on the heels of a Marantz CD84. But I think I'm safe. SPDIF from the 70x0 chipset is strictly for the hardcore MJ types.
Old 8th April 2005, 04:17 PM   #7
diyAudio Moderator Emeritus
jean-paul's Avatar
You are aware that there are TDA chips inside it Rfbrw ??
It's only audio
Old 8th April 2005, 07:25 PM   #8
Lourens is offline Lourens  Europe
Default dig out from Marantz CD-74/CD-84
Hi rfbrw,
The schematic diagram that came with my CD-74 (SAA70xx/TDA1540 - my first cdp ever, now stored) shows a dig out on a pcb coded PW10 and a lead coded JW01 (JW02 = GND). Unfortunately the actual RCA connector on this machine is not connected (yep, labeled "N.C."). I could send you this schematic, if that should help.
Only the mk II verson of the CD-84 has a working spdif out, but fitted with SAA72xx/TDA1541 or an early version of this DAC coded N2992, with gold pins... (according to a 1985-86 brochure).
I'd love to fit my beautiful CD-74 with a spdif out! So why don't you share your hard core skills & expertise with us, rfbrw, eternal gratititude will be yours......
groeten,
Lourens
Old 8th April 2005, 07:30 PM   #9
Bernhard's Avatar
I would like to have the datasheet SAA7000 too.
In a Denon DCD1800R it is combined with a PCM53 DAC and I wonder if they let the 16 bit DAC work with 14 bit only, or can SAA7000 output 16bit ?
Old 8th April 2005, 08:08 PM   #10
1. Yes
2. It is the TDA1540P not the trendy TDA1543 or that overrated waste of sand, the TDA1541/A.
3. Best of all, it will be bypassed.
SPDIF Output from SAA7020, SAA7000 lscangus Digital Source 75 29th October 2010 08:10 PM
SAA7000 chipset Duo Digital Source 4 20th February 2008 05:28 PM
Possible to connect something to a SAA7000 ? 00940 Digital Source 8 26th May 2006 08:12 AM
Page generated in 0.08487 seconds (79.95% PHP - 20.05% MySQL) with 10 queries
